Question about Motorola Mobility V265
LCD lights up, but is blank when i open the flip
I dropped my phone in water a week ago. i dried it out and replaced the battery. it works, but i am unable to view the anything on the lcd screen. when i open the phone, it lights up, but it's blank. i have another v265 phone that is not working, but the lcd screen might still work....can i just replace the lcd screen from the other phone?
    Scholar:
  • 91 Answers
Yeah that is possible. make sure you know what you are doing and don't damage the working LCD screen it might just be easier to replace the whole cuircuit board that the LCD screen is on.
Posted on Mar 01, 2007
My nokia e51 dropped in sea salt water ten days ago, I dried it and opened its cover under the keyboard and cleaned it , it worked very well for a whole week, the problem is now the battery is not...
The sea salt water has made the charging port corrode. So get a screw driver, open the phone and bring out the charging port. The charging port is where you put our charger. Use methylated spirit to brush the charging port and the panel where the charging port is place.
Dry it for 30 minutes and couple the phone and it will start working fine.
Regards
Sep 12, 2011 | Nokia E51 Cellular Phone
Net 10 phone just wont work
Does the inside of the phone show ANY signs of having been in water? Might be slight residue, condensation, corrosion? My GUESS - he dropped it in water and took a week to dry it!!!!
Aug 17, 2007 | Motorola Mobility V170
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
My Treo 650 cellular phone cannot turn on.
Same thing happened to me about a month and a half ago. I own a 680. I had to open the unit to try to dry where water leaked in. A cellphone technician advised me to try a vaccum cleaner to **** the water. But I didnt do it. I used paper towels. Next get a Ziploc bag and fill it with about 1/3 cup of rice. Leave it sealed for a week. Rice absorbs any remaining humidity inside the cell. Then, try to assemble it partially to test it. If nothing happens leave it another week. I used a hair dryer, at some point to make sure it was dry, but dont overdo it cause extreme heat can damage components. Be careful at opening, I disconnected the LCD data ribbon and its been difficult to stick it back together. Now today, finally I was able to turn it on and everything works fine with the exception of the LCD light. I can see whats on the screen but I need an external light source, maybe replacing the LCD screen will fix it. Good luck with the repair.
Oct 03, 2009 | Palm Treo 650 Handheld
Wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
May 31, 2009 | Cell Phones
My phone is a samsung u700. its screen is blank and its not displaying anything. backlight on . what could the problem be.only light from the
first remove the battery just 5minites .................then display is out try change dis play .......
May 30, 2009 | Samsung Cell Phones
Dropped in water
I got my i870 from my sister a week ago, i got it for boost mobile but the ear speaker doesnt work either, i took it apart and i ordered the flip part of the phone which comes with the whole top section. It should work after i put the new part. it was only $26 off of ebay. the parts were only held up five screws. really easy but you have to be careful and gentle.
Dec 31, 2008 | Motorola Mobility i870 Cellular Phone
I got it wet!!
The first thing is to know if the phone dropped in salted or fresh water. If was in salted water, forget it, you let it pass so much time, but if was fresh water, try to open the phone ( get a Torx 6 or 8 screwdriver in home depot) and use pure alcohol with and old toothbrush and clean the mineral deposited on the circuits, gentle brush it and let it dry, then reasemble the phone a it will work perfect
Sep 20, 2008 | Nokia 6133 Cellular Phone
Phone goes blank
The Flexcable need to be replaced on the phone.
Jul 21, 2008 | Motorola Mobility RAZR V3
Sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they will usually come with instructions and the screwdriver you need. A T6 torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
Jan 14, 2008 | T-Mobile SidekickĀ® 3 Cellular Phone
Motorola Mobility V265 Logo
122 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
