Question about Epson Stylus Photo 915 InkJet Printer
ERR 1C i have changed the cartridges on my printer but the display moniter is now flashing, err 1c,and i cannot clear it.i have switched the printer off for about a minute and removed the power cord but no good. can you help please.
  • Magpiedon Nov 18, 2007
    Same problem as Stewpot ... however printer has not been left without cartidges (as suggested bu "guest" solution) and worked some 10 days ago. I have changed both cartridges and turned power off etc without luck also. Any other ideas rather than get anew printer would be appreciated.
Hi I had same problem, error 1c denoted black ink cartridge is not installed properly, I took it out and put it back in - then got error message 1 Eb - this denoted black ink cartridge is empty - I replaced the black ink cartridge and now the printer is happy and I am happy - hope this helps :) Richard - I know epson cartridges are not cheap but it was not as pricey as a new printer ;)
Posted on Apr 16, 2008
Epson printers are known for this sort of thing. You left the printer too long without cartridges and the heads dried up. Buy a new printer and this time don't buy Epson.
Posted on Sep 19, 2007
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
Jun 11, 2014 | OKI Electric Industry B4300 Led Printer
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
Dec 02, 2013 | Electrolux Dishwashers
ESP-6TM Sprinkler System - Everything on the display is correct. Then the unit reads "Err" and will not activate. Tried reprogramming with no luck. What is the problem?
When it gives the "ERR" code, usually it flashes the zone number after that. This will only do this when the system is set to "ON". Sometimes, error codes pop up for no apparent reason, with no fault in the system, and attempting to clear the alarm is the first step in troubleshooting the system. When turned to "ON", and the "ERR" alarm is displayed, hit the ENTER button. This should clear the alarm for a single zone. If another ERR is displayed, clear it also by pressing ENTER. Turn the system back to OFF, wait 10 seconds, then turn to ON. If no ERR codes are displayed, the system should cycle properly on next use. If ERR odes are still displayed, make another attempt to clear them, and re-check. If they cannot be cleared, trace down circuits to the valve boxes for each zone, and make sure that all wiring connections are good, dry, and tight. Solenoid valves can be removed with the water shut off, and tested at the control box by wiring them into the terminal strip site for a known good circuit, and then operating that circuit. If the valve is good, you'll see and hear the diaphragm move.
Best regards, --W/D--
Jun 02, 2011 | Garden
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
After entering pulse secs it shows error 1C
You posted under Intermatic ET70215CR timer.
Best source of information about this product is 1) Manual and 2) Intermatic.
1) Manual: Click product number to download manual
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
a) ET70215CR Manual search for 1C shows following: ERR 1C One or more of the selected circuits has a program conflict.
-For example: program 1 says ON 8pm Tuesday, OFF 9pm Tuesday, but program 2 says opposite.
-Another example: program 1 says ON 8pm Tuesday, OFF 9pm All days of week
b) Manual also says: NOTE: Error messages are subject to change with later software revisions.
2) Intermatic customer service:
http://www.intermatic.com/customer%20service.aspx
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Intermatic ET70215CR Electronic Energy...
Err message on D70 and clock flashes
D70..err display...problem with the loader section switch,rotating while loading is open,so get it repaired.
Mar 07, 2010 | Nikon D70s Digital Camera
Err err err
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Epson Stylus Photo 915 InkJet Printer Logo
1,095 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
