Question about Cisco Catalyst 3560G (WSC3560G24TSS) 24x1000 Mbps Networking Switch
Routing on l3 switch - Cisco Catalyst 3560G (WSC3560G24TSS) 24x1000 Mbps Networking Switch
    Problem Solver:
  • 16 Answers
Zdt12011fa dishwasher is built in and the flood alarm is in operation - how do I reset?
First you need to remedy failure or any leakage than reset appliance.
Under Reset I mean to delete all alarm stored in memory.
1. Turn off the dishwasher.
2. Press and hold S1 while switching on the dishwasher. Keep
holding the Program button until:
- LED L1 blinks, L2 and L3 is on
- Release S1
3. When L1 is blinking, L2 and L3 is on, press the S1 before L2 and
L3 is turned off.
- LED L2 is blinking, L1 and L3 is turned on.
4. Wait till L1 and L3 is turned off, then press S1
- All used LEDs flash 5 seconds on 1 second off repeatedly.
- If buzzer is equipped, it beeps for 5 seconds
- The alarms saved in the memory are erased
5. Switch off the appliance.
26259192-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Dado
Aug 14, 2016 | Zanussi Dishwashers
Dear Sir I have a CISCO WS-C2948G-L3 switch with me, when I power it up I get the following message :- ROMMON: Cold Reset frame @0x00000000 ROMMON: Reading reset reason register ROMMON: Valid...
It looks like the IOS is bad or not not there.
You need to instal a new IOS onto the switch.
For more help during installation you can refer
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml#cat4k
Dec 09, 2010 | Cisco WS-C2948G-L3 Catalyst 2948G-L3...
How do i wire pressure switch 034-0195
Just put in series after the switch before the wirings
go to the electric motor. Put the two electrical wires
to L1 and L2 (Line In). L1 must be with normally closed ontact L3 while L2 must be with L4. (L3 and L4 - is Line out) for the motor terminal wires. Before connecting wires at L3 and L4, Check for continuity at L3 and L4. Set the muti tester at 1 x 10 Ohms..Then put the multi tester probe on it. The reading must be infinity or no reading at all. Then
connect the motor wires at L3 and L4.
Oct 30, 2009 | Air Tools & Compressors
How to create vlan in nortol 3510 L3 switch
You would need to trunk the VLANS to the router and create sub
interfaces and then, create access lists applied to
the interfaces to control inter vlan communication. I hope this helps,
Router interfaces something like this, may not work on all versions of
IOS:
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description VLAN1_Servers
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.255.0
interface FastEthernet0/0.2
description VLAN2_QA
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VLAN3_DEV
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description VLAN4_FIN
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
Aug 01, 2009 | Nortel Enet Routing Switch 3510-24T Incl...
Real diffrerent between Router & L3 switch
Following links might be helpful to you:
http://web.ivy.net/carton/rant/l3-switch/switch-l3intro.html
http://compnetworking.about.com/od/hardwarenetworkgear/f/layer3switches.htm
http://www.e-tutes.com/lesson8/networking_fundamentals_lesson8_3.htm
http://nixcraft.com/computer-networking-internet-broadband/454-difference-between-layer-3-switch-router.html
Thanks for contacting Fixya.
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
L1, 2 and L3 versus COMM
what kind of light switch are you replacing??? assuming house light switch???
one way or two way switch??
I have not come across the type of switch before.
L1, L2 is just label as line 1 and line 2, comm is usually refer to common (ground wire-white).
is the red wire-hot???
Oct 23, 2008 | Electrical Supplies
Where is the module for the day time running lights on a dodge ram B 1500? 1996
Notes CIRCUIT OPERATION - CANADA
On Canadian vehicles, the low-beam headlamps operate when the ignition switch is in the RUN position and the headlamp switch is OFF.
When the ignition switch is in the START or RUN position, circuit A1 from fuse 15 in the Power Distribution Center (PDC) connects to circuit A21. Circuit A21 powers circuit F18 through fuse 19 in the fuse block. Circuit F18 feeds the Daytime Running Module (DRL) module.
Circuit L20 from the headlamp switch connects to DRL module. Circuit L20 is HOT at all times.
The DRL module receives the vehicle speed sensor input from circuit G7. Circuit G34 from the DRL module provides power for the high beam indicator lamp in the instrument cluster.
Circuit L4 powers the low beams of the headlamps. When the headlamp switch is OFF, the DRL module powers the low beams on circuit L4. When the headlamps are ON, the multi-function switch powers the low beams on circuit L4.
Circuit L3 feeds the high beams of the headlamps. When the operator flashes the headlamps with the stalk of the multi-function switch, the DRL module senses voltage on circuit L3. When it senses voltage on circuit L3, the DRL module stops supplying power to the low beams on circuit L4.
Circuit Z1 provides ground for the DRL module.
Aug 19, 2008 | Dodge Ram 1500 Cars & Trucks
My coolpix l3
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
The mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch.
Jul 23, 2008 | Nikon COOLPIX L3 Digital Camera
Network diagram
you can feel free to call to this mobile number ill help u 09620077956.cuz we are the solution providers.
Feb 22, 2008 | Cisco ASA 5510 Firewall
Cisco Catalyst 3560G (WSC3560G24TSS) 24x1000 Mbps Networking Switch Logo
62 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
