Question about Apple iPod touch
My ipod shows up in Itunes but not in "my computer." how do i fix it?
    Sergeant:
  • 236 Answers
I may be mistaken, but I believe the new iTunes/iPod's will not show up in MY Computer by design
Posted on Dec 08, 2008
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
My ipod touch shows a USB cable and a itunes sign...
This is called "Recovery mode"
Connect it to your computer running iTunes and restore from your last backup, and you should be all set.
May 20, 2010 | Apple iPod touch
Ipod will not show up on itunes
1. Reset or restore your iPod for a try, this can fix many general iPod problems. 2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library. http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html 3. Upgrade or re-install iTunes for a try, this is the method that I got from Apple technical support. Hope it helps. Contact me if you have any other question.
Mar 05, 2010 | Apple iPod nano
I plug my ipod into the usb plug in and it wont show up in itunes so i cannot update it or add new songs and playlist. it shows the charging symbol but will not show up in itunes
1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems. If you don't know how to do that, you may refer to this iPod tips
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
4. Download and install the latest version fo iTunes for a try.
5. You may try this iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well
If you have any other questions, feel free to email me.
Jan 30, 2010 | Apple iPod nano
My iPod doesn't show up on my computer!
try to log out of itunes, and set up your own account, log in each time you connect your ipod, your ipod has it's own serial number, and your computer tries to open up ipod 1 even when ipod 2 is being used.
Nov 15, 2008 | Apple iPod nano
Ipod wont show up in my computer or itunes...
Unistall ITunes and all Ipod Software.
Remove Ipod for the computer.
Reinstall all software. Make sure ITunes is updated to the current version.
Aug 16, 2008 | Apple iPod nano
Have you tried resetting either ipod? In order to reset it, you just need to hold down both the menu button and the center button at the same time until the ipod turns off. then the apple will pop up on the screen and it will start up like normal. If this doesn't fix the problem for either ipod, then most likely the problem is with itunes or your computer. I would say that if it doesn't even show up on your computer anywhere, you're probably missing a driver or something.
Jun 30, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
you might have already tried this, but just to eliminate the obvious
1. download and install the latest version of itunes
2. unplug everything
3. restart computer and restart ipod
4. plug back in and see what happens
Feb 08, 2008 | Apple iPod nano
Apple iPod touch Logo
19 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
