Question about Reddy 165000btu Kero Heater
Pump pressure won't go above 2.5psi.
My heater turns on and tries to run but it only runs for a few seconds and turns off. I replaced the rotor, filters, and end covers. I checked the pump pressure and have tried to adjust it many times but it will not go above 2.5psi. It is supposed to be set at 5.6psi. Any suggestions?
  • 944 Answers
Here is the link to the manual if you need it. I guess you have gone through all the pump pressure procedure as they describe on page 7. http://12.153.20.74/manuals/102439-01E.pdf Check if you definitely have a seal around the pump plate and at the shaft etc. Check if the blades actually do fit or possibly are an incorrect size, and that any gaskets or seals are not the incorrect thickness giving a gap down the sides of the blades. check that lubricating grease etc. is not clogging normal blade operation. check all inlets/outlets are clear it sounds to me like the problem has to be inside the pump. unless there is something fundamentally wrong with the motor or it's power supply. Hope this helps :)
Posted on Mar 14, 2007
Low fuel pressure. Won.t start but pump run.s then shuts off
Pump is only supposed to run a few seconds to prime system with key on. Should run in start position, but check for restricted fuel filter and for bad fuel pressure regulator.
Jul 14, 2015 | Cars & Trucks
I have a 93 K3500 with a 454. Truck was running fine, started no problem, ran great. Driving the other day, turn the corner and the engine quit. Cranked the engine, fired up for 2-3 seconds then quit, ...
Before starting the engine, the fuel pump should only run for a few seconds when the key is first turned, to pressurize the fuel system. Even though the pump appears to be running, you may either have not enough or too much pressure for the engine to keep running (fuel pump or pressure regulator). I think it may just be a coincidence the engine quit while turning a corner, but the gas in your tank may have been so low it sloshed away from what is likely a very old pump, starving it and causing it to failure.
Jul 03, 2017 | 1993 Chevrolet C1500
2005 V-6 mustang , fuel pump will not run
it's designed to only run until it builds a specific pressure. once the pressure is reached it turns off. if the car isn't running and you suspect the fuel pump drop the tank take the fuel pump out. use two pieces of wire and hook it straight to the battery and see if it continues to run. if it run continuously thats is not your problem as it will continue to run trying to build up pressure but it won't be able to considering it's not in an air tight system
Jul 16, 2012 | Ford Mustang Cars & Trucks
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
My 96 yukon wil not start. Sounds like it will crank over but won't. It is not the fuel. I changed the ignition coil still won't start.
try spraying some carb cleaner into a vaccum hose and see if it will run. If so then you have ignition but no fuel delivery. If not then you have an ignition problem. make sure you hear the fuel pump hum when you turn the key to the run position. It should run for +/- 5 seconds then shut off. remove gas cap and listen for fuel pump operation through the fill hole. If you can hear the pump then you have a fuel injection issue. If the engine starts and runs for a few seconds then shuts off then you can suspect the crank or cam position sensor. The fuel pump runs through the oil pressure switch which could also be an issue.
Are you able to start the truck with application of the gas pedal?
Sep 22, 2011 | 1996 GMC Yukon
Won't start after short trip like its vaper locked
STARTING / IDLING PROBLEMS / MISSING
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they just stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from FORD, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Have you hooked a scanner to the computer and checked the oxygen sensor(s)? If they are bad they could lean out the engine.
VAPOR LOCK
Check the following:
Cooling system working properly including fans.
Under hood fuel lines touching coolant or heater hoses.
Fuel lines under vehicle close to or not shielded from exhaust pipe, converter, muffler. Fuel lines pinched or crushed.
Fuel filter changed recently.
Fuel pump pressure.
Cheap(Bad) gas.
Aug 26, 2011 | 2003 Ford Taurus
Dayton 70,000 btu kerosene heater only runs consistently with 3/4 of a tank of fuel or more. Once it is below 3/4 it keeps shutting off. I have cleaned filters, tried to set pressure but pressure won't go...
If you can only get 4 psi from the pump then you have a problem with the rotor. This could be from the vanes not coming out properly of if you have replaced or serviced the rotor you may not have the clearance set properly between the pump ring and the top of the rotor.
Make sure to inspect the pump cover for any small cracks..
If you pump pressure in not enough the unit will not be able to pull fuel from the tank and you will see the burner cone slowly start to go from the orange color to a dark color and the unit will shut down.
Feb 10, 2010 | Dayton (3E386) Heater
Takes multiple times to start
I think you have a faling fuel pump or a bad pressure regulator allowing fuel pressure to bleed down when the engine is off.
Try this test - When you start the car for the first time of the day, turn the key to "ON", wait a few seconds, turn the key off. Wait about 15 seconds, turn the key to "ON" again, wait a few seconds. Then wait one final time for 1 seconds and try starting the car. If it starts right away, that means fule pressure is bleeding of due to a bad check vavle int he fuel pump, a bad fuel pump or a bad pressure regulator.
The reason for the procedure is because when you turn the key to "ON", the fuel pump runs for 2 seconds and then shuts off if the engine is not running. The 15 seconds wait is for the power and fuel pump relay to cycle off before it will run the pump again.
Let us know how the test comes out. The fuel pump is in the fuel tank and hums when it is running.
Mar 01, 2009 | 1999 Chevrolet Silverado 1500
Reddy heater 70,000 with factory thermostat will run a few
Set the pump pressure. If correct check the nozzle. Desa recommends annual replacement.
A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics.
Dec 12, 2008 | All-Pro Forced Air Kerosene Space Heater...
1998 Dodge Ram 4X4 Pickup
Try disconnecting the battery (both terminals and let set for a few hours) with ALL the accessorries on lights-heater-radio etc. This will draw all power from your system, then recconnect battery, it's worth a try even if it doesn't solve your problem. Bill
Nov 07, 2008 | 1998 Dodge Ram 1500 4WD
Heating & Cooling Logo
80 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
