Question about Dell Latitude C840 Notebook
Dell latitude C840
Touchpad mouse and or keys for mouse do not work, upon fresh install of xp pro when you get to the first screen that requires you to use the mouse pad its froze up and will not move. install a usb mouse and it works fine, changed memory and hard drives, cant find a solution. thanks guys..
  • hedeviltazz Dec 08, 2008
    sounds good, but, this is happening when you are doing a fresh install of xp pro,when it gets to about 32 mins mark there is the first box that comes up and you have to choose an option and click next. the mouse pointer is frozen.
  • hedeviltazz Dec 09, 2008
    thank you, i will give that a try
  • 903 Answers
Try using the usb mouse then go into control panel>system>hardware>device manager. Click on the +sign next to touch pad or pointing devices and right click on touchpad, then click on uninstall. Reboot the computer, unplug the usb mouse and the touchpad should be picked up as new hardware and be re-installed.
Posted on Dec 08, 2008
  • Debs
    Debs Dec 08, 2008
    so why not try continuing the installation with the usb mouse, (plug the mouse in first), then when the installtion is complete and the computer reboots it will pick up the touchpad as new hardware. (Remove the usb mouse once the installation is complete and it is rebooting)
My touch pad will not work. I have to plug in a mouse just to operate my laptop
look like you need to re-install the touchpad driver for the laptop. here's how to do it.
go to http://www.dell.com/support/home/us/en/04/product-support/product/latitude-xt2/drivers
select if your running xp, vista or widows 7 in the Operating System section in the drop down menu.
scroll down to Mouse, Keyboard & Input Devices
Select Dell Touchpad / Pointing Stick
download it by clicking on download and run it to install it
Dec 22, 2013 | Dell Latitude XT2 Laptop Computer (Intel...
Dell Latitude C840 issue. Have 4 input USB 2.0 PCI card adapter that is connected to side USB 2.0 serial port, but external HD and devices are still running at 1.1 speed (as if I plugged into the back USB...
Hi, I haven't got a Dell but try this site for the USB driver that is missing. With XP there is no support for USB2, an updated driver is required. Did you download the drivers from Dell? If not, that could be why as they may be old drivers.
Oct 29, 2013 | Dell Latitude C840 Notebook
Sound drivers doesn't work after reseting on dell latitude c840
keep updating windows to sp3 then reinstall sound driver
Dec 23, 2012 | Dell Latitude C840 Notebook
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Dell latitude touchpad mouse is sticking and right
you are facing a defective mouse touchpad...have it repaired
Feb 16, 2010 | Dell F3534 Touchpad
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Phrases jump to another line
The Latitude you have most likely has the touchpad plus the dreaded pointing stick. The problem you are having is also known as "wandering cursor" where your cursor will move around the screen on it's own. Try these solutions:
1. Go to Dell.com and download the latest driver for your touchpad. In the touchpad properties, try to disable the pointing stick.
2. If all else fails, I have removed the keyboard and disconnected the cable for the pointing stick which always solves this problem. If you decide to take this approach, you should know your way around the inside of your laptop, take anti-static percautions, etc. You can download a service manual for your laptop from dell.com.
db
Feb 22, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
BLACK SCREEN AFTER START UP IN XP PRO
Hi you may try follow:
1) go bios setup screen set default configuration and save it and test same error go next
2) take out wireless card and test same error go next
3) reinstall winxp at same HD test same error go next
4) change a HD and install winxp test
nothing solved above is motherboard hardware trouble, need to repair
Dec 21, 2008 | Dell Latitude C840 Notebook
Dell Latitude C840 Notebook Logo
372 people viewed this question
Alun Cox
