Question about SanDisk Sansa e250 MP3 Player
Mp3 sansa e250--problem with music
I have song and when i want to listenning this song,the mp3 player write a thing like bad song and i dont know how delete this song and in the folder MUSIC or Playlist,i didn't see this song who are ''bad'' help me please
  • 8,596 Answers
Renew your sub
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Dsp fail
dont format the player by connecting it to pc... pls alwasys open the drive folder and delete the datas....
Apr 06, 2010 | Coby MP-C844 (256 MB) MP3 Player
Dont know how to delete old songs
That's fairly easy actually, just connect it to your computer and open "My Computer". Then select the drive your MP3 player is located (like mine is E:, but yours may vary). If you look around, you'll find the music folder (or if in MSC, it's in the root folder). Just locate the song and right-click and delete.
Apr 25, 2009 | GPX MW-3847 MP3 Player
Deleted songs still showing, but not there
you must reset your mp3 our refresh either our
Mar 19, 2009 | SanDisk Sansa e250 MP3 Player
How do i delete songs
1st plug your sansa into the computer then go to my computer and click on the sansa e 250 icon then click on the "media folder" and after that click on the songs folder then a bunch of folders will come up click on these and they hold your songs from there you can delete them.
May 11, 2008 | SanDisk Sansa e250 MP3 Player
LOST SPACE!
same thing happened to me it still doesn't work and mine is supposed to hold 500 it only holds 150
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Songs
to add or delete songs you simply view it as a hard drive then drag and drop the sings you want on the folder marked sansa.  to delete do the same thing in reverse.
Feb 12, 2008 | SanDisk Sansa m240 MP3 Player
Listening
well i had same problem try this
1.take all songs to computer (and pictures ,movies)
2.make sure your computer dont shows hidden(needed files) files.. if you are using xp or vista do this controll panel/folder options
3. delete all music,pictures,movies on your mp3/mp4 ( dont delete any thing other!! )
4.pull the music back to it
/it worked for me well well hopes it works
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Removing bad tracks
I beleive your player saves a lists as well as the song itself. the easiest way to fix it is to (if possible) use windows explorer, goto your player and look for a folder that says "albums" or "list", scroll thru and delete the folder of the songs that you have deleted.
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
Bad tracks won't delete
Have you tried updating the firmware. Even if it is the lastest edition, download the firmware manually and run the software. Then format in Windows Media player. Best Regards Keith
Jan 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
