Question about GPS
If i install t4a my mapsource does not work
I downloaded the latest vesion of mapsource on my computer, but now my T4A does not want to work It says there is a problem with the T4A-8001 installation. But it work just fine before i downloaded the new mapsource. I already uninstall T4A and install it again, but it still doesn't work. can you please help me?
5 Suggested Answers
hydetech
  • 113 Answers
SOURCE: blue chart pacific v8.5- mapsource
Try skipping the installation wizard and use your coupon code to unlock the maps/GPS online at Garmin's website.
Also if you downloaded the mapsource software online, the download may have been corrupted.  You may have to contact garmin tech support to try another download.
Posted on Oct 26, 2007
  • 4090 Answers
SOURCE: Mapsource doesn't open.
usually by installing the maps!
Posted on Jun 23, 2009
  • 24 Answers
SOURCE: USB driver installed but not finding unit
Check the 6 phillips head screws that hold the front and back parts of the case together. If you have ever had the battery changed and the screws were not snugged down all the way, the USB connection on the back may not be making contact with the circuit board inside the GPS. If the screws are snug, then you may need to take the unit apart. If you are comfortable with this, removed the 6 phillips head screws. CAREFULLY pull the front and back parts of the case apart. There are wires holding the two halves together so handle these parts carefully. Looking inside at the circuit board, there are some small circuit trace pads (about 4-5 or so), in the area where the USB port would line up. Use the alcohol and q-tip to gently clean these pads and also the little spring connectors on the other part of the case. Carefully, reassemble the case. There is a rubber gasket that fits between the two parts of the case. Make certain it is not kinked or crimped. Gradually snug down each of the 6 phillips screws, working your way from one side of the unit to the other and criss-crossing. You may need to use your fingers and pinch the unit together as you snug a specific screw. When the unit is reassembled, try the USB again. If it still does not work, it may need to go back to the factory.
Posted on Jan 23, 2010
walesarumi
  • 6993 Answers
SOURCE: my Garmin is 255 minus the W-I have on my desk top
Read through the manual on the below link:
http://www8.garmin.com/manuals/UsingaGarminGPSwithPaperLandMaps_Manual.pdf
If that was not helpful, follow the below procedure since you have successfully downloaded the map:
  • Launch the web browser with Garmin Communicator installed.
  • Navigate to the MapQuest website.
  • Select the "Directions" tab.
  • Enter your "Start" and "End" destinations, then click "Get Directions."
  • Edit the directions to fit your needs. You can drag the navigational line to adjust the turn-by-turn directions, remove highways from the directions and add additional destinations as needed.
  • Connect the Nuvi 255W to your computer using the appropriate USB cable.
  • Click "Send" located above the map interface.
  • Select "Send to GPS."
  • Click "Send" to transfer the map data to your Nuvi 255W. The MapQuest data will be saved to the "Favorites" section of the Nuvi 255W.
I hope you are able to get back on track now.
Good luck.
Posted on Oct 28, 2010
Where do i take may receiver for repair
Contact the following:
http://shure.custhelp.com/app/answers/detail/a_id/4053
Nov 21, 2013 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
Repacement knob for Shure t4a reciever?
DeadCatDot.com Sells the knob for the Shure T4A receiver.
Jul 08, 2013 | Audio Players & Recorders
Is sm58 wireless mic compatible t4a receiver-shure
The "SM58" is just the cartridge on the top. It would depend on the model of handheld transmitter. The model number is on a sticker in the battery compartment.
Nov 07, 2012 | Shure SLX24/58 Wireless Microphone System...
Our Church sound system
They have been discontinued for many years.
Jul 08, 2012 | Shure Audio Players & Recorders
Bcm2045a driver
bjvzhbcjh hjv vklahajfh k
ksjb b bs
fbldfk;lgdfg
fdkg fl;kgl;dfkg; dflkgl;dfkl;ghk;hlkgl;hk;tiohwrot t wiuty iouoi fjghwruhyw h gwerioyu poihjef;lkdj fadjkg a; a;h t4a k; d
rigj rgjoitrwy o[iu rw[]]
Jul 26, 2010 | Billionton USBBT02-B Bluetooth Wireless...
Shorted out AC on Shure T4A receiver, need schematics
You can get the repair manuals/schematics by emailing Shure at service@shure.com
May 09, 2010 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
Modify frequency on a T4A shure reciever
It is not an easy task. First, the crystal needs to be replaced, and possible 6-8 other components that surround the crystal. Then, the rest of the circuitry needs to be retuned for it to operate correctly.
There is a place in Chicago called Delta Audio (773-764-3634) that has the equipment to do this.
May 10, 2010 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
The T-4 has fixed frequencies, the only way that maybe could work is to send it to your distribution centre.
Regards,
Gerard
Mar 30, 2010 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
Repair manuals and schematics can be obtained from the Shure service department by writing to serviceweb@shure.com
Mar 17, 2010 | Shure T4A DIVERSITY AC RECEIVER (CV) T4ACV...
GPS Logo
193 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
