Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
Changed mic , opened up and it looks great.tightened up female connecters that the mic plugs into at mic connection.still radio channel leds won't light up .radio won't work.speaker might make a popping noise indicating power when turning on. if i put pressure on the side of the mic connection at radio face it will work.but not always.
  • imbman1970 Dec 11, 2008
    OK, I LOOKED AT IT AGAIN AND IT POWERS UP THE METER AND THE METER LIGHT COMES ON. IF I TAPE OR HIT IT ON THE HOUSING THE CHANNEL SELECTER WILL COME ON AND THEN GO RIGHT BACK OFF. SOME TIMES IT WILL STAY ON AND I CAN USE THE RADIO UNTIL THE CHANNEL SELECTION LEDS GOES OUT THEN RADIO IS IN OP. METER STAYS POWERED UP. THE MIC IS NEW AND PUTTING PRESSURE ON THE 4 PIN CONNECTOR WAS ONLY MOVING THE RADIO AROUND. THANKS FOR THE HELP. BW
    Problem Solver:
  • 4 Answers
Cobra 148 shows no wattage output on external meter but does show good modulation.
Posted on Oct 17, 2009
Cobra 148 gtl cb no recive, the power supply put 20+volts inti it, what could be the problom.
Your power supply is providing 20 volts? THAT is the problem. This radio should be connected to a power supply capable of providing anywhere between 12 ~ 13.8 VDC. Twenty volts is WAY too much. You may have cause significant damage to the radio if it was connected to that voltage for any period of time.
Jan 12, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have a 1990 cobra 148 GTL with 5 pin side-mounted mic. I recently bought a Barjan 5 pin noise canceling mic. Is the mic compatible with my cb, or do I need to change the wiring? Larry
The wiring is not likely to be the same.
The information on the radio is here:
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
You will likely need to open up the mic to identify what your wires connect to to determine the correct oreintation. it is possible too you may find one of the models listed was used by Barjan and is nothing more than a rebranded microphone.
Feb 17, 2012 | Cobra Radio Communications
Wy receive is low. it seems like i cant turn the volume up high enough. this is a side mic plug 148 gtl
Hi Light, my name is John. Welcome to FixYa. If that is the one I'm thinking about, might be a GTL or LTD. Turn the RF GAIN to MAX. Thanks for choosing FixYa......Happy holidays.......John
Dec 15, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
148 GTL PROBLEM
sounds to me like the final driver is blown, try replaceing it with a new one.
Apr 24, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
173 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
