Question about Canon ZR100 Mini DV Digital Camcorder
JVC GR-D33U won't play back some tapes
I have a JVC GR-D33U that generally works fine (I've already had it serviced for the infamous "lens cap" issue). However, when I recently tried to play back some previously recorded tapes---which used to work---I only get audio from the tape with no video (the solid blue screen appears.) Interestingly, video images /are/ there in fast forward or rewind. Recently recorded tapes seem to work fine, it's the older ones that fail.
I bought a head cleaner per some advice I'd seen in this forum and ran it through a few times but that hasn't helped yet. I don't want to run it through too many times because the JVC cleaner instructions warn against cleaning more than three times in succession. (It's not clear how long you have to wait before cleaning again.)
I don't have immediate access to another minidv camcorder to check the tapes there, so I thought I'd see if anyone here had any ideas.
Cheers
  • sdtoooc Dec 08, 2008
    Thanks for the quick response! I had the unit repaired for the lens cap/CCD issue back in early '06. I read your comment to mean that tapes recorded before the repair will have problems (having been laid down with the old alignment), but newer recordings (post fix) will be OK. Sounds like a good explanation, but I have tapes I recorded earlier this year that have the playback problem, shouldn't those be OK if your theory is correct? Any other ideas?
    Oh, and I'll lay off the cleaning.
    Thanks again,
    Scholar:
  • 107 Answers
I still thinking alignment is matter on your CAM and one more thing in your CAM it have the rubber roller it call itself pinch roller if that worm out or defective it can damaged the tape and depend the thickness and branch of those tape it make different resul you can check yours tapes which one is no picture open the lid door and look carrefully any mark deteriorate on the tape
I sugges you to bring it to JVC to check the pinch roller and re-align the tape guide and back tension it delicated and need special instruments and software service it
Posted on Dec 08, 2008
    Scholar:
  • 107 Answers
The tape cleaning won't help this problem, it is alignment on tape guide and back tension, like you mentioned it had been service before after they fixed the lens cap issue, usually they connected to computer to adjusted may be they missed. So I sugges you to bring it back to them if it is still under warranty or direct to JVC and take the old tape, ask them to try it after they align this unit, DO NOT use tape cleaning again because you can see picture on the new recorded
that mean the video head is good
I hope that give you some ideas
Camera seems to think that the lens cap is on, there is no image (and no the lens cap is not on)- jvc mini dv camcorder gr-d347u The message "Lens Cap" appears when the camera is turned on, there is no...
There are 2 possibilities for that symptoms in JVC GR-D347U camcorder is either aparture in lens mechanism is stuck and does not pass image towards CCD Imager OR ccd imager itself got bad.
Qualified camera tech can fix it because it requires expertise.
If you want to fix it, download service manual from HERE for small fee, that will help you how to disassemble/ apart camera and part info etc.
Thanks.
Aug 13, 2009 | JVC GR-D347U Camcorder
I have a JVC Model NO. GR-D33U and the screen is black and the screen says lens cap, but the lens cap is off! WHat's going on? I just bought a new battery and it still is doing the same thing.
problem on ccd assamble u have chaing that part...first open urcamera and remove lense unit ..then u can c back side of lensunit there i a small board..u remove that board from lens unit...and u can c the ccd assamble....
Jul 26, 2009 | JVC GR-D33US Mini DV Digital Camcorder
Camcorder keeps asking me to remove lens cap
Contact JVC, they fix this error FREE. They fixed my GRD-50. It's a common fault with lots of them. Give it a go. Good luck.
Dec 07, 2008 | JVC GR-D20EK Camcorder
Camcorder says lens cap is on when its not
This is problem of bad CCD Imager in your JVC GR-D32U model. This part need to be replaced.
JVC offers Free of Cost repair for such problem in same model cameras.
Click JVC CCD Program for details.
Nov 09, 2008 | Cameras
Lens cap
CCD Program for This Model - GR-D33US JVC has received reports that in certain circumstances, this model may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at JVC Factory Service Centers. Click this Repair Request link to download a Repair Request Form and find your nearest location.
Please call our Customer Care Center at (800) 858-6442 if you encounter any problems in obtaining a free repair. We apologize for any inconvenience and are appreciative of your understanding and support.
Jun 30, 2008 | JVC GR-D33 MiniDV Digital Camcorder
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
Feb 02, 2008 | JVC GR-D33US Mini DV Digital Camcorder
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Jvc GR-D33U
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Dec 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Black screen
JVC has acknowledged a fault on their side that will cause certain models to display the "lens cap" error, and they offer free repairs, your model is also on the list. Here's a link to the JVC site : http://www.jvcservice.com/service/custnoticecamcorder.asp?ReqType=CCD hope this helped ;]
May 16, 2006 | JVC GR-D33US Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
213 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
