Question about Compaq Presario 5000 PC Desktop
Internet connection It is not detecting the cable for internet to my desktop computer and in manage network connection for LAN the status is a network cable is unplugged when it is not unplugged. It stopped working all of a sudden. I hook out the cable and then i hook in back the network is connected again and a couple of minutes it turns back the cable network is unplugged.Same situation again and again. i change the cable many times still the same. It is windows xp and the network adapters is VIA Rhine II Fast Ethernet adapter. I check this device it say it is working properly. When i connect the internet connection to my laptop it is working properly also. Any help is much appreciated
  • Velaphi Masoha May 11, 2010
    Did you try a working known working cable to me it sounds like the ethernet cable is fault.
    Problem Solver:
  • 5 Answers
Try reinstalling the modem driver mite be corrupt....
Posted on Dec 08, 2008
  • 107 Answers
Reset your ISPs modem
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I am using acer aspire M5800 for about 1 year 3 months. Just yesterday, i cannot connect to the internet at my home desktop using my ethernet adapter. I contact my internet provider, it says that the lan...
Please check your device manager, and look for the Network Adapters to see the status of your Network Card. First check if it is detected in the Network Adapter, If there is a yellow expression mark near it then you may need to reload the driver. Otherwise you can do a ping 127.0.0.1 on a command prompt (DOS) if it replies back then your Network Card is working finely.
Cheers.
Mar 29, 2011 | Acer 91.AB370.001 Network Adapter
Emachines EL1850 internet connection problem, brand new out of the box computer will not connect to the internet. Its not the modem or an internet problem, as i'm using the internet and modem to write...
hi,
other computers are working fine in your modem?in that case you need to check if your pc can detect the modem,or you can check if the ethernet driver (for LAN connection) and/or wireless driver (for wifi) are installed correctly...you can check that in the device manager if the drivers are properly installed
if Windows 7 - click start ; on the start search area, type device and the look for device manager
look for network adapters and you will see there you lan and/or wireless adapter
Thanx
Jan 05, 2011 | E-Machines eMachines Desktop PC
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
Formatted pc and now its not detecting internet connection.. checked ipconfig but loks like my pc doesn't show no IP address.... everything else in d pc works fine except for the internet connection....
Did you reformat with the manufacturer's discs? If not, you are likely missing the LAN drivers for your NIC (Network INterface Card). Right-click on My Computer and select Manage. this will bring up the Device Manager screen, and if you see a yellow question mark next to the LAN driver then this is the reason.
Nov 09, 2009 | Dell Dimension 4550 PC Desktop
Can't access internet with dell studio slim 540s
Click on this link below to go to the Dell support for you computer. Just copy and paste into your browser. Update your drivers for network. I already have that portion opened for you.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=STUDIO540S&os=WLH&osl=en&catid=&impid=
Hope this helps. Let me know if I can help you with anything else. In the future please remember to add any brands and models that you are reffering to.
JimmyC
Oct 04, 2009 | Dell Computers & Internet
Problems connecting to internet on laptop
check your IE internet connetion settings follow ff. steps.
1. open Internet Explorer browser
2. go to tools, internet options or options
3. under options, select "connections" tab
4. under connection tab, select "LAN settings"
5. under LAN settings check if "Automatically detect settings" is mark check if not mark it check.
6. click apply to save your settings and click ok
7. close your browser and open it again
if you still having a problem,
try this steps to chek your wireless settings
1. rigth click the wireless network status bar near desktop time & date
2. select status
3. under status, select Properties
4. under properties, select TCP/IP settings and click properties
5. check if "Obtain an IP address Automatically" is selected if not select.
6. click also obtain DNS
7. save your settings and close the properties
8. after saving, wireless will reconnect
9. open your browser for Internet
hope this will help you
Dec 16, 2008 | Linksys WRT160N Wireless Router
HP Pavillion dv2000 is not detecting the network cable for lan
ok...so...unhook the cable completely
go to control panel
device manager
and see if the ethernet device is clear or has some mark on it..you may need to remove that or disable it, then re install
Nov 21, 2008 | HP Pavilion dv6000z Notebook
No Broadband connection after hard drive replacement
1) First of all check your connections
2) Check if your network card drivers has been installed after your OS installation.
Go to My PC >> right click "Properties" >> Hardware >> Device Manager >> Network
Be sure that not appears this yellow symbol ( ! )
If yes, go to dell support website and get the drivers for your network card.
here: http://support.dell.com/
If your network card is OK, do this:
Open Internet explorer >> Go to >> Tools >> Internet Options >> LAN Settings >> Check the mark
Ok
Open your browser and see what happen..............
Oct 23, 2008 | 2wire 1800HG Router (RG1800HG00)
Compaq Presario 5000 PC Desktop Logo
226 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
