Question about Canon PowerShot G5 Digital Camera
Lens adapter mount cover is broken
I'm not sure how it happened since someone else did it, but that plastic ring that goes around the lens that you're supposed to be able to take off if you wanted to mount a telephoto or wide angle adapter is stuck in the wrong position and can't be taken off.  No matter how hard I try to twist or pull in either direction I can't get it to come off even if I hold the release button down at the same time.
Having the same problem ...G5 can't get the original plastic ring to come off in order to change to a different lens...
Posted on Jan 05, 2012
2 Suggested Answers
Quack
  • 542 Answers
SOURCE: Telephoto and wide angle lenses
Yes, you can use different lenses with the PhotoPC. To find out what lenses are compatible with the PhotoPC, contact TIFFEN.
Posted on Sep 12, 2005
HOW TO PUT Fotodiox 49mm Filter Thread Macro Reverse Mount Adapter Ring for Sony E-series
The ring threads onto the front of any lens with a 49mm filter thread, just like a filter. The front of the lens then fits onto a camera body, effectively mounting the lens "backwards" or reversed. With most lenses, this allows the lens to focus very close, for close-up or "macro" photography.
Mar 14, 2013 | Fotodiox 49mm Filter Thread Macro Reverse...
How to remove adapter ring from a fujifilm3800
Hello Ken, If this camera was pre-owned, you may have one that someone glued the ring on because of broken tabs !!!! I have had a couple of these cameras that had that problem.Normally they just twist off with very little effort.
Good Luck, Russell
Jan 22, 2013 | Fuji FinePix 3800 Digital Camera
Replacing NIKON 55-200MM BAYONET MOUNT RING PART. I have two of the three plastic guides broken on the bayonet mount. Can i buy this part and can i replace it myself. Sam
If it's the VR lens:
http://uscamera.com/jaa79851-b37.htm
If it's not the VR lens:
http://uscamera.com/jaa79351-f.htm
As to whether you can replace it yourself, can you use a screwdriver and a soldering iron?
May 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
My Nikon DX AF-S Nikkor 18-55 3.5-5.6G ED has a broken mount ring. Can I get a replacment mount? if so, from where?
You can get the part directly from Nikon, and the repair is fairly simple. Look at the step-by-step of the same repair done on this page:
http://www.gmtruckhq.com/artwork-design-forum/how-fix-broken-nikon-dslr-lens-mounts-3271.html#post125961
The part # and Nikon contact info is listed there as well.
Oct 17, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Lens mount plastic is broken on Lens
Unfortunately your lens is one of the kit versions which were built as cheaply as possible with a plastic lens mount. They were never intended to be repaired, but to be fair they usually seem to last quite well on the 18-55mm versions but the 18-105mm is heavier and longer and I've found that the plastic mount is particularly intolerant to any handling errors on this lens.
A professional repair will normally cost more than the lens is worth, but you can sometimes buy new replacement mounts.
Use your favourite search engine to look for part number 1C999-488. Unfortunately they're rarely in stock whenever I've needed one. You may also want to search for a scrap lens with a good mount which you can replace yours with, but scrap lenses of the correct type usually have faulty or badly worn plastic mounts as well.
Carefully assess your lens before making the repair: unless it's in perfect working order in all respects except for the broken mount then you'll be better off buying a new or used complete replacement lens.
Aug 31, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon d90 lens plastic mount broke
I feel for you. exactly the same happened to me but i was looking to upgrade lens so i used it as an excuse.the piece is called a bayonet. what lens is it, is it the kit lens. my lens was unfixable so  am afraid as the mount is plastic the whole lens is a right off, if it was a metal mount it would be worth fixing. sorry
Mar 13, 2009 | Nikon D90 Digital Camera with 18-105mm...
How to fis additional lens for canon power shot S1 IS
On the lower right side of the lens (as viewed from the rear) is a small button that releases the ring around the lens barrel. Removing the ring reveals a bayonet-style mounting flash that allows you to attach a lens adapter for extended telephoto, wide angle, or macro capabilities. Visit your photographic stockist for info on what is available
Apr 23, 2008 | Cameras
Adapter ring cover problem
Maybe the adapter ring release button is stuck after you pushed it in to release the cover. Try giving it a good flicking until you are sure it has popped out.
Jan 27, 2007 | Fuji FinePix E550 Digital Camera
Canon PowerShot G5 Digital Camera Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
