Back to:
Tags:
Katadyn Kata CC-191 Shoulder Case KTCC191 Camcorder
I have a new comcorder, my question is How can I...
By Riddle - usenet poster
i have a new comcorder, my question is How can I play my tapes through my TV?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Mini Me
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
That really depends on the type of input(s) your TV has. You'll get the best picture quality if you can connect your camcorder directly to your TV's S-video input. If your TV has no S-video input, use its composite (RCA-type) inputs. And if your TV has a set of A/V inputs on the front panel, hooking up your camcorder will be extra quick and easy.
If you have an older-style TV with a single RF input for audio and video, an easy work-around is to run your camcorder's signal through your VCR's RCA-type audio/video inputs (nearly all models have them). If neither your TV nor VCR has these inputs, you can make the connection using an optional RF modulator.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on i have a new comcorder, my question is How can I play my tapes through my TV?:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
Katadyn Kata CC-191 Shoulder Case KTCC191...
Tape will not eject
Hi, I'm having loads of trouble with my camcorder. First...
top does not rise and side panel does not open.
Hello, I own a panasonic sv av 100 mini digital...
I get this message on screen. Tape does not roll. I tired...
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
