Question about Canon imageRUNNER 400S Copier
BLANK COPY WHY DOES COPY COMES BLANK TOTAL PLAIN PAPER. NOTHING PRINTS PROBLEM WITH IP BUT DID NOT REPAIRED HELP ME TO REPAIR THR BOARD.
  • Anonymous Mar 17, 2008
    blank or very light copy with printers
  • 42 Answers
The blue developer handle needs to be swung to the 3 0clock position. then try again
Posted on Jun 21, 2007
Red color paper is not clear copy
Posted on Jan 13, 2009
    Problem Solver:
  • 11 Answers
U r toner unit is proper locked. u see this unit lock handle. u lock this handle half position it means handle position is don,t go up or down. then its comes u re-insert ip board conection
Posted on Sep 18, 2008
  • 62 Answers
The developer engagement handle needs to be engaged at the 9 O'clock position. Sometimes it can go ''off cam' and prevent toner reaching the drum. If this is not the case, inspect the transfer assy. Lower the transport bed by moving the green handle, undo the screw below the black assy to the left of the green handle and remove the assy. If the roller is not held secureley at each end, or the springs are missing, then toner transfer cannot occur from the drum to the paper.
Posted on Aug 27, 2007
SOURCE:
Ricoh aficio 2045e
try to shake the toner cartridge and reinsert it in the printer, if still getting the blank paper, try to print a stand alone test page or if its a multifunction printer try to make a copy and check if its printing or not
reply
Dec 07, 2013 | Office Equipment & Supplies
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
It will not print. It has new ink cartridges..There are no error messages. Print heads have been cleand several times. It will not print a test pattern. It will not make a copy. Only blank paper comes out.
Head cleaning is mechanical process, printing is electrical process. Nothing print out at all? Printer mainboard problem. Lost electrical to head. Usually caused by short circuit at head. Track on aicaxz solution for reference to repair board. Note: if you have experience in electrical circuit, test mounted fuse at board.
Dec 31, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Hp F4180 No copy to Plain paper
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
May 30, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
BLACK INK COPY FUNCTION
Something is definately damaged and with the low cost of printers and the high cost of repair I would recommend just replacing it. Hope you find this helpful,
George
I'm also disabled with a broken neck :-(
Jul 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Panasonic KX-FPG376 Plain... Problem:
Thermal paper roll upside down. You can only print on 1 side of thermal paper. also could be the thermal head in which case not worth repairing. Lawrence
Mar 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
The fax will not print anything
2 possibilities
1- you did not remove the plastic film on the cartridge
2- the printhead has dried up
Dec 04, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Canon imageRUNNER 400S Copier Logo
127 people viewed this question
Clive
Clive
old marine
old marine
