I lost my usb wrieless card modem e67. now i need it to install it on my another PC. how could i get this driver installer
  • 105 Answers
Try to download from driverguide.com
Posted on Dec 08, 2008
Compaq Presario 5220 Desktop Windows 98 internet: Dial-up Can a DSL card be installed or would I need to go with a wireless USB? And would wireless USB work on Win98?
You can install a network card inside the computer. You will need a PCI or an ISA card. (I know PCI network cards are easy to find at most of the computer shops.) See this site for how to install a card: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07111&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=93139 . However you should open your computer and check the space between the devices in the slots in the computer. There is an AGP slot with a video graphics card, 1 PCI/ISA slot with a modem (default specs), one free ISA slot and one free PCI slot. However depending on the graphics card one of these slots may be blocked by the card. You'll either need to get a card that fits the available slot or remove the modem and use that slot.
Here are some PCI 10/100 network cards: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=587&name=10-100%20Ethernet%20PCI/ISA . Most of these are compatible with Win98. I'm not sure if there are any gigabit NIC with Win98 drivers.
Wired and wireless USB NIC adapters exist. However, you will be limited to the USB speed. If you have USB 1.1, that will be really slow. Most likely your computer will require a reboot anytime the connection is lost.
I hope this helps.
(who recently removed an internal modem to put in a PCI gigabit card in a newer desktop than yours. The procedure was straightforward and improved network performance in the household immensely. The failing on-board NIC was tying up the router for everyone.)
May 12, 2011 | Compaq Presario 5220 (388098-003) PC...
Hi, the ethernet port located in the back of my computer appears to be faulty. I am unable to connect to a modem/router successfully due to this problem, also my USB ports don't appear to be working. Can...
If your lan card is faukty then you have to replace the LAN card. But as regards the USB ports not functioning the best thing to do is to install the usb drivers for your PC. When you install the USB port drivers for the PC the PC will be able to accept plug and play USB internet modems.
The drivers for your usb port can be located when you go to device manager select USB ports and it will take you to the drivers for the ports.
Hope this solution has been helpful?
Dec 30, 2010 | Computers & Internet
I have a dell that lost the drivers for the sound and for the internet. I have the sound working now but the device manager says that the PCI Modem driver is not installed and I cant install it. Keeps...
I show the modem driver as this one
http://tinyurl.com/2em86nm
as for the wireless, the are multiple options, you'll need to select the driver for the card installed:
http://tinyurl.com/2a2mt3t
Sep 24, 2010 | Dell Latitude D510 Notebook
I'm tryin to install the sierra wireless card 598 on win 98 manually. Does anyone know how to do
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
  1. you may need the sierra CD device driver that comes with your wireless card.
  2. next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
  3. depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
  4. run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
  5. after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
Nov 09, 2009 | Sierra Wireless 598U USB Modem
I have trouble locating and instaling drivers for qualcom CDMA 1x USB modem. i have windows vista home 64 biti have lost d installation CD plzzzzzzzzz help
If you are running 64 bit vista then you most likely also have an available ethernet connection. Forget USB ethernet connection is much faster. If ethernet card is bad, have it replaced...worth it.
Oct 18, 2009 | Computers & Internet
Wireless wont stay on
- Kindly install the latest driver for the wireless card.
Mar 13, 2009 | Acer Aspire One PC Notebook
I want nokia 6030 modem drivers
Install Nokia PC suite on your system.After installing PC suite.just connect your mobile phone through USB cable.Your system will automatically install the driver from PC suite.PC suite is available with CD that is provided to you with your handset.or you can download it from Nokia's site.
Thanks
Feb 18, 2009 | Nokia Card Phone Dual Band Version 2.0...
Installation software for Huawei EC 325 USB modem
I lost the installation Cd please help me
Dec 29, 2008 | Computers & Internet
Lost driver cd
my installation cd had just broke,and i could not use my driver because of it,...if you could help me...just email me......thanks and God bless
Oct 22, 2008 | D-Link DFM 562IS (DFM-562IS) Modem
Nokia siemens ADSL Modem c2110 USB Driver
How can i download usb driver form ADSL Modem c2110 i want to down load the siemens c2110 usb modem driver.Please help me.
Sep 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
