Question about GE JES735WJ Microwave Oven
Microwave is not working. when i connect to plug , it is not working and it is not showing any time not rotating .
  • chkspyrobbe Feb 07, 2009
    After making baked potatoes the unit shut down and still after cooling down has no power
  • 78 Answers
1. Check the power outlet.
2. M/W has 20 Am fuse located behind control panel. Most time it burn out.
3. If after replacing the fuse M/W still not working,
call technician.
Posted on Dec 08, 2008
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have samsung 1850w CM1929 Microwave it shows e41 and does not work.
if you have not plugged out the microwave...then do so now.the trick is that when you plug out the microwave it will reset the microchip.after you have plugged it out ....then you plug it back in after about an hour.if that does not work then it is time to look for a tech to repair your microwave.the problem is that the diode or the cap is bad.
Mar 04, 2011 | Samsung MW1080STA Microwave Oven
Plate will not rotate
Yes there is a small gear reduction type motor that drives the turn table. The motor can be replaced.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Help inside tray will not rotate
check rotated plate and connecting surface ok.
Nov 12, 2007 | Emerson Black Microwave Oven
GE JES735WJ Microwave Oven Logo
81 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
