Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi washer dryer model-WJD 1257 W
My washer dryer has decided to stop emptying and having to empty through the front while sat in front of it, it has also now started to leak out of front drawer, tried cleaning powder out etcc, tried unkinking pipe, still happens, can anyone help, have three kids so its essential i need it working.................
  • 247 Answers
Not sure about the drawer leak, but have some ideas about the refusal to empty. Have a look at the section in your instruction manual (copy here: http://www.serviceforce.co.uk/pdfs/U23119.pdf) about cleaning the filter (pages 20-21). Check the filter isn't completely choked. Expect quite a lot of water to come out when you remove the filter. While you've got the filter out, have a look in the hole it came out of. At the back of the cavity you should see the pump impeller (looks like a four-bladed fan). With the power off(!) give this a spin with your fingertip. It should be free to turn (although it's normal for the movement to be very notchy). If it won't turn, see if you can find anything jammed up in it. Keep looking in the same cavity. Somewhere about halfway back, usually on the top wall, you should find a large hole (this is how the dirty water gets into the pump). Slip your finger as far into this as you can without getting it stuck, and just check nothing is blocking it (20p coins are favourite problems here). If you've still drawn a blank, then without replacing the filter turn the power back on, set the machine going on a spin cycle, and look to see if the pump impeller is whizzing round. Don't be tempted to touch it, as it can rap your knuckles very hard. If it won't turn, you probably need a new pump. Replacing a pump is a pretty low-stress affair. It's more or less obvious where everything is meant to go. You can get a new pump from one of the internet parts suppliers for about £35 (it's worth shopping around, as prices very wildly). Hope this helps a bit. A.
Posted on Feb 22, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
and click on START ANIMATION for a walkthrough of what you need to do
Jun 23, 2011 | Electrolux EW1000i Front Load Washer
Kenmore front Loader washer leaking from bottom
I want you to run an empty load, pour 3-4 cups of white vinager into the soap dispencer, this will flush out detergent buildup, it sounds like the unit has a buildup of soap and is oversudsing, the vinager wash will stop it from happening, if this stops the problem cut the amount of soap you are using in 1/2. If it does not let me know, good luck
Jun 07, 2010 | Kenmore 43142 Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Tromm does no stop filling
you got water in the pressure valve hose ,,,,, keep running in on drain till it clears or the best it to remove the top of washer, pull off the little hose and blow thru it to clear it
Oct 19, 2008 | LG WM1814CW Front Load Washer
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
610 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
