My Monitor-No picture, power led blinking, ticking sound
    Scholar:
  • 135 Answers
That is NOT good..
when booting the PC do you see anything on the screen ?
if not your monitor is fried... time to replace or repair
Posted on Dec 08, 2008
HOW DO I FIX CLICKING SOUND AND BLINKING POWER LIGHT IN COMPAQ MONITOR FP5315. THE MONITOR FAILS TO POWER.
the power transistor on the SMPS of the monitor is blown,
you will need a skilled person to diagnose and replace the component
Aug 29, 2016 | HP Compaq Fp5315 15 Lcd Monitor With...
17" flatron crt monitor only green led blinking and tick tick sound .No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | LG Flatron F700P 17" CRT Monitor
My lg studiowork 700s has stopped working
look listen and dance not matter how you performance keep it calp and trust it
Feb 20, 2014 | LG Studioworks 700S 17" CRT Monitor
No picture, power led blinking, ticking sound in an LG 702b monitor
our both the monitor having same diffect.
Out put transistor will be short.
replace it and check the other parts in the horizontal section
Aug 02, 2011 | SAMTRON 55V 15" CRT Monitor
My PT-50LC13's LAMP and TEMP light blinks 4 times and POWER light blinks 8 times continuously with 2 second intervals. I replace TY-LA1000 and FBL12G12L2CS Fan, but didn't fix the problem. Can anyone tell...
Listen carefully to the TV after the relays click. If there is a mechanical ticking or snapping noise after power On, replace the lamp because HV is present (causing the ticking). If there is no ticking sound, replace the ballast. You can confirm this by using the LED blinking pattern to localize the problem. refer to Service Manual or technical guide on the panasonic website for more help diagnosing LED patterns
May 01, 2011 | Televison & Video
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
After powered up, no video signal, power led blinking very fast
maybe u have to check ur video card if its is properly attached to the mobo...
Nov 06, 2009 | Computers & Internet
X2 MW19R is ticking and no display?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details or if you have any questions.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Mag Innovision 765S power supply light blinks and monitor power led blinks and no picture
I'd suggest looking at the mainboard. I assume the blink is rapid? A slow on, followed by a short off and back on again is normal. The fast blink thing is a mainboard issue, and the absence of blink (or light) is power "supply dead."
There is a problem transistor on the mainboard that seems to be the problem most of the time. Replacing it takes about 5 minutes if you have the tools and the talent, and the parts cost under 3 bucks at Radio Shack. Just pick up a pack of NPN switching transistors and de-solder / solder your way to a working monitor. There's usually only one on the board, so it's easy to spot.
Nov 18, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
