Hi.... i need your help please. About internet connection problem. it is not detecting and it manage network for LAN the status is cable network is unplugged when it is not unplugged. It stop working all of a sudden and then a couple of minutes its turns back connected again and then unplugged again.... same situation. It is a windows xp. The network adapters is VIA Rhine II Fast Ethernet Adapters. When i check this device it say it is working properly.Any help is appreciated.
  • 107 Answers
Reset you Modem (the box your ISP gave you)
Posted on Dec 08, 2008
The wifi detect but not detecting the internet
Hello. 1_Check if the router connected to the internet by the LAN cable. 2_Check if the router connected properly to the internet by dial up your connection information. If all of these are correct that mean the mac address on the router don't match your laptop this is for the security of your WLAN network.
Sep 02, 2011 | Computers & Internet
I am using acer aspire M5800 for about 1 year 3 months. Just yesterday, i cannot connect to the internet at my home desktop using my ethernet adapter. I contact my internet provider, it says that the lan...
Please check your device manager, and look for the Network Adapters to see the status of your Network Card. First check if it is detected in the Network Adapter, If there is a yellow expression mark near it then you may need to reload the driver. Otherwise you can do a ping 127.0.0.1 on a command prompt (DOS) if it replies back then your Network Card is working finely.
Cheers.
Mar 29, 2011 | Acer 91.AB370.001 Network Adapter
My acer 4310 connects fast to wi-fi pero pag internet cable na as in ung dsl hindi gumagana
When you plugged in the ethernet cable, does it show on your windows tray (lower right corner of the screen) that the LAN is connected? It should show you "Connected" if you hover your mouse on the LAN icon.
Try also to plug in the ethernet cable to a different port on the router, and that the port number on the router is showing a solid green led light.
If all has been observed and still you cannot connect, look if the network adapter for your lan is working. RIGHT click your My Computer or "Computer" and select Manage. The Computer Management window will open. Click on the Device Manager on the left to show the list of devices on the right. Look for Network Adapters and click the + sign. See if your LAN adapter is not showing any yellow exclamation point. Also, right click on it and select Properties. You should see the device is working properly under status.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Acer Aspire 4315 Notebook
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
I cannot connect to the internet using the router the computer does not detect the router please help me with my problem thanks.
we ll start with the physical connections.
1.take ethernet cable n connect one end of the cable to the modem and the other end to the isolated port on the router(internet port) and then connect the computer and your router with other cable(any lan port).refer the chart on the router to distinguish the internet and lan port.
2.check the light status on the modem and router.
router lite status-power,alphabet i lite,wireless lite(lollipop lite) and the number light lit up(depends on the port eg port no:1 connected number 1 light lit up).
3.check the ip address and default gateway address.
steps:In windows(xp,2000 etc),click on start->click on run->in the search tab type cmd->dos prompt window opens,type ipconfig and u ll get ip address and default gateway address(192.168.1.1 or 192.168.0.1).note it
In vista,start->in the search tab type cmd->dos prompt window type ipconfig->u ll get the address as specified earlier.
4.open the browser,type the default gateway address in the address bar and press enter.The login window ll ask for username and password. username-admin
password-password.
5.You ll enter the netgear smart wizard page.Run the setup wizard at the left side (blue screen).select yes and detect the type of connection.
6.If it is a cable modem-dynamic ip detected and click next.check whether the dns address is given automatically from isp and click apply.Then click on basic settings under setup menu and in that window in the router mac address select "use computer mac address "option and click on apply.Now click on router status under maintenance menu and check the ip address in internet port(it should not bo 0.0.0.0) and in lan port(eg 192.168.1.2 or 192.168.0.2).
7.If its a dsl modem-the type of connection ll be detected as pppoe.click next.configure your router with the username and password provided by the isp and click on apply.The router ll save the settings and then check the internet port and lan port
address as given in the previous step.
8.Now we have to configure the router for wireless settings(both modems same configuration).
*click wireless settings under set up menu.
*In that page enter
name(ssid):netgear1
region:us
channel:11
mode:g and b.
In security options select wep and key1 give your telephone number so that you wont forget the password.we have secured the n/w.
9.scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.
10.you ll be able to go online wirelessly if there is any problem delete the preferred networks.
I have given you all the steps with examples to help you configure the router.hope you ll fix the issue and further assisstance im ready to help u but pls give details about your operating system,type of modem and no of computers so that it ll easy for me to troubleshoot.
Sep 28, 2009 | NetGear WGR614 Wireless Router
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Jun 24, 2009 | HP Pavilion dv6000z Notebook
LAN internet connection problem in COMPAQ V 3000 notebook
Just connect the lan cable from the modem port saying "DataIn" to your laptop, select Automaticaly detect IP setting and let it assign via DHCP. Once it gains the ip (usually 3-4 minutes) use any java enabled browser (like ie,mozilla firefox) and go to any site it will automatically redirect you to Tata Indicom login terminal and fill in the required blanks and you are connected to the internet.
Jan 19, 2009 | Compaq Network adapter
HP Pavillion dv2000 is not detecting the network cable for lan
ok...so...unhook the cable completely
go to control panel
device manager
and see if the ethernet device is clear or has some mark on it..you may need to remove that or disable it, then re install
Nov 21, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
