Question about SanDisk Sansa e250 MP3 Player
Screen problems ok. my sansa recently had a problem with the headphones. it was playing out of only one phone. so, my stepdad fixed that. now, after he fixed it he tried turning it on, and the buttons all work, but the screen doesnt show anything its completely black! is there a way to fix this without taking it in to a shop?
  • bryan pauers Mar 30, 2007
    the sodder joint was busted, so all he did was take the back off, take the battery out, take the next part off, and sodder the sodder joints back. i dont recommend doing it though, because look what happened to mine. the screen doesnt work anymore.
  • kahwebb Feb 15, 2008
    I was listening to my sansa, (I was in my left coat pocket) while I was walking toward the bus stop. I saw the bus coming up the road and ran so that I would not miss it; as I was running my sansa went dead. Just black! It did not fall out of my pocket, It was not next to anything hard in my pocket I can't understand why this happed. Is there anyway to get my sansa repaired and how?
Buy a new one, or get over your old one. you might as well just buy an ipod.
Posted on Feb 19, 2008
Get the stapler for the screens
Posted on Jul 17, 2007
SOURCE:
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa will only play through the right speaker/headphone unless you jiggle the cord and hold it in the perfect spot, then it will play through both speakers/headphones. Is there a way to fix this...
This is a common problem, it is the lead in the headphones get a new headphone set that will sort you,IF it is the actual jack, soldered onto the motherboard, this then will required to be resoldered. I think, however just replacing them will work fine.
Apr 01, 2010 | SanDisk Sansa e260 MP3 Player
Only the left ear phone works
Try updating the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa Clip 1G's screen has completely gone out &
It is not a good mp3 player - you have more than one hardware issue. The replacement headphone jacks are not available, and would require major electrical work to install anyways (bootleg DIY fixes, such as those shown on YouTube, only succeed about half of the time). That issue alone would justify getting an in-warranty exchange.
But, due to your screen problem, the LCD controller circuit is also bad. Mp3 repair for such issues is not cost-effective AT ALL, even in areas where such services are available - you could buy 6 of these for the cost of repair.
That player has a 1-year warranty - go ahead and call Sansa and get it replaced.
-Tha Mp3 Doctor
Feb 27, 2009 | SanDisk Sansa Clip MP3 Player
AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Only hear out of one side of headphones with sansa player - tried 5 pairs...
i had the same problem, the headphone jack on the sansa is loose. I opened it all up, and saw that one of the connections on the headphone jack was loose. you can sauter it and it should work clearly again.
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
Hi, my sansa e250 has sound come out of only one head phone no matter how many headphones i try the same happens
The jack in the e250s is not made of adamantium, so it can actually go bad; however, if you try different headphones and thus determine that either:
  - All the headphones simultaneously went bad in one side
  - Your left ear has issues
  - The Sansa is only cranking out one channel; and
     -the jack feels a little off, or
     -perfectly good mp3s are being played off-balance; AND the balance has not been misconfigured in Settings.
...well then, the plot's moving forward and you can get your ear fixed, or stop the cat from killing your headphones, or re-load Sansa or Rockbox.org firmware, or fix the Settings, or see to the appropriate repair to the jack (depending on your warrantee status and skill with soldering irons and ordering off Jameco.com etc.)
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260
Hi, I have the same problem but sometime is the left channel & sometime the right channel. I tested multiple headphones and it's alway the same problem. FYI the problem begin after a firmware update. With the original firmware the problem never append. It start with the firmware ver. 01.02.15E. Today I have downloaded the new firmware version (01.02.18E). I hope it fix this annoying bug. Bye
May 01, 2007 | SanDisk Sansa e260 MP3 Player
Self Panning Headphones
I recently purchased a Sansa e280 and in three weeks of regular use it developed a similar problem, with music cutting out from playing in stereo to mono, coming out of one headphone speaker. Sandisk tech support told me to reformat the device and install the latest firmware, which I did, but the problem continued and occured more frequently. I have returned the player back to the seller and I shall not be getting another one. A nice Ipod alternative from Sandisk, but from what I have seen written about in forums, the Sansa e200 series appears to be buggey with problems.
Apr 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
