Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start embroidering, the light is green to start, push the buttom and inmediately get a message in the computer that safety device is activated. I tried to sew also and it does not work
  • 48 Answers
Also make sure the needle is all the way up. If it is half way down the machine will not work and beeps.
Posted on Nov 11, 2011
    Scholar:
  • 110 Answers
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Posted on Dec 08, 2008
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
My futura ce 200 quantum embroidery machine is all set up to embroider and the green light is on when I push to start nothing happens. When I push the back stich it goes back to the orginal position and...
Change the fuse in the plug failing that it could be the inline fuse inside the machine normally near where you plug the lead in, if youcan get to that it is a matter of changing it, and the Hoop must be detachedwhen powering on! Otherwise it will not start. Hope this will help you. Good Luck.
Jul 20, 2011 | Singer CE-200 Quantum Futura Computerized...
Which format should I use for my Singer futura CE-200 when I download embroidery deisgns
The Futura should run any format program but its dedicated program type is XXX so if you have that option I would use that one.
Jan 18, 2011 | Singer CE-200 Quantum Futura Computerized...
The bobbin case on my Singer CE-150 embroidery sewing machine pops out when I am embroidering. What's wrong
It must not be inserted right, check your manual and if you do not have it handy, go to singerco.com and download one for free. You can cause real damage if it is loose, so be careful that something isn't broken and not letting it seat right.
Sep 11, 2010 | Singer CE-200 Quantum Futura Computerized...
What embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
Apr 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Button hole maker on Singer Quantum Futura CE-200
Try to adjust the stich width on the machine maybe it can help
Mar 07, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
My start/stop switch will not begin sewing
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
Dec 23, 2008 | Singer CE-200 Quantum Futura Computerized...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Embroidery Machine
There is a numbered dial which has numbers and the letter E.  Turn it to E for embroidery.  Thats is the correct tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
421 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
