Question about Kenmore 15218 Mechanical Sewing Machine
I HAVE A KENMORE 38515718 SEWING MACHINE AND IT LOOKS LIKE THE NEEDLE THREAD IN WRAPPING AROUND THE PIN THAT THE BOBBIN SITS ON IN THE BOBBIN CASE IS THIS SOMETHING THAT I CAN CORRECT
  • lcmhayden Dec 08, 2008
    I MEAN THAT THE THREAD FROM THE NEEDLE IS LOOPING AROUND THE BOBBIN PIN I DON;T REALLY KNOW HOW ELSE TO EXPLAIN IT
    Genius:
  • 1,239 Answers
Hi
ncorrect or NO top thread tension, Incorrect threading
Re thread top thread and thread machine with presser foot lifted allows thread to locate into the correct thread tension route.
Thread has not been pulled into thread tension unit- re thread, make sure thread is kept taut while threading.
Posted on Dec 08, 2008
    Genius:
  • 1,550 Answers
Just adjust the bobbing tension.
Top and bottom tensions need to coordinate,like if one is loose, the other should match.
You can correct it .
You need to remove the bobbin and then remove the metal plate beneath the bobbin, return it and then rethread it .
  • 734 Answers
OK PLEASE DESCRIBE DETAIL OF UR PROBLEM
  • futureloginn
    futureloginn Dec 10, 2008
    ok,
    please go to the web site of your SEWING MACHINE.
    Thanks
Needle thread is wrapping around the bobbin case on my juki ddl 5550N industrial. I've set the timing and it looks perfect to me...stitch looks good. Except when I stop and pull the work away from the...
Not to familiar with the industrial machines. However, even with domestic models. the position of the 'needle' bar at the time you remove your fabric, does make a difference as to weather it pulls our smoothly or, you are going to get that "extra" loop. Needle should be half way up or all the way. maybe this might help
Sewing Machine Tech
Oct 23, 2013 | Kenmore Drop-In Bobbin 16231 Mechanical...
Needle thread wrapping around bobbin case.
Hello Crystal, I also have had problems in the past with drop-in bobbins . I had to experiment with different model bobbins . The cause I found was due to the bobbin was not tall enough in the drop-in bobbin case. When sewing , the bobbin would rock in the bobbin case and the top thread would get caught on the bobbin instead of going over the top of the bobbin, causing the rats nest that you described. I would recommend finding a taller bobbin to fit in the bobbin case. There are about five different bobbins that will fit in there, but only one that will work properly. Knowing the exact model number of your machine would be a great help to finding the correct bobbin.
Oct 08, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Feb 20, 2009 | Singer 5050 Mechanical Sewing Machine
Brother sewing machine cs6000i. Less than one year. The upper thread wraps around the bobbin caseing and jams.
check you tension on the top thread and see if you have it threaded the right way. Also see if the indent of your needle "the indent down by the hole on the needle" is facing the hook by your bobbin case that grabs the thread when it comes around.
Greg
Jun 13, 2008 | Brother CS-8150 Computerized Sewing...
Kenmore 15218 Mechanical Sewing Machine Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
