Question about Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens
Nikkor Lens Fix
I'm fairly new to photography. I recently took pictures that turned out sunlit and faded. I believe I might have scratched my lens. Is there a way to safely clean it without causing additional scratching. If it is scratched is there a way to replace it, or is it done for?
  • maele_photog Dec 08, 2008
    I'm sorry I meant repair not replace. thanks!
    Scholar:
  • 48 Answers
The fading (flare) you see could simply be a finger smudge or other stuff. One little scratch won't do it, you'd have to take sandpaper to the lens to see obvious flare.
It's actually harder to scratch a modern lens than most people think. When it happens, it's usually during cleaning when a tiny piece of grit is on the surface and gets rubbed in by the cleaning cloth/lens tissue.
So the first step in cleaning a lens surface is to be sure you remove all dust and dirt without rubbing. The lens cleaning kit you can find in any camera store is a start -- it contains a blower brush. With the lens surface to be cleaned facing down (so dust falls away), brush gently with the tips of the bristles to dislodge stuff. Then use the blower to blow it away. Repeat as needed.
If you still see dust and dirt which seems to be stuck on the surface, take a piece of the lens tissue from the kit and put several drops of the cleaning solution on it, enough to get it pretty damp. (Always apply cleaning solution to the tissue or cloth, never drop directly on the lens surface.) Cover the lens surface with the damp tissue, pressing it into the corners, but do not slide the tissue across the surface. Just lift it away. Repeat with another section of tissue.
Then take a full sheet, wad it lightly, and wet it. You are going to rub lightly, using a roll-up motion as you move the tissue so that dust/dirt is lifted away from the surface and fresh tissue is always coming in contact with the surface. Repeat as needed until there isn't any visible stuff.
Final cleaning can be done with a fresh piece of tissue and a bit of mist from your breath. Mist the surface, and lightly polish with the tissue to remove any remaining cleaner residue.
Posted on Feb 08, 2009
Nikon Nikkor 18-55mm, The lens feels stripped. How do I fix that
The Nikon Lens 18-55 wide angel inner lens loosens locks lens no picture
Aug 19, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I used the Nikon D90 with Lens Kit 18-200 mm, and I also bought the new Lens call Nikkor 75-300mm. But when I connected the new one (Nikkor 75-300 mm) in my camera and took some pictures, after that I...
That's the Nikon error message for a lens with aperture ring set to something other than the minimum (i.e. highest number).
The camera insists on controlling the aperture ring, and to do so, the ring must be set to the minimum setting.
Unless it is a "G" lens, which has no aperture ring whatsoever.
The camera body sets the aperture of the lens wide open while auto-focusing, and displaying through the viewfinder. When it comes time to flip the mirror up and take a picture, the camera dials the aperture to the setting you (or the camera) have selected.
Dec 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
My Nikon DX AF-S Nikkor 18-55 3.5-5.6G ED has a broken mount ring. Can I get a replacment mount? if so, from where?
You can get the part directly from Nikon, and the repair is fairly simple. Look at the step-by-step of the same repair done on this page:
http://www.gmtruckhq.com/artwork-design-forum/how-fix-broken-nikon-dslr-lens-mounts-3271.html#post125961
The part # and Nikon contact info is listed there as well.
Oct 17, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikkor Lens Cannot Manual Focus
It sounds like you had the lens set for manual focus when you took the A / M switch plate off. If this was the case then when you but it back together the little arm behind the plate is on the wrong side of a moving gear assembly.
To fix, remove the auto/manual focus switch plate from the camera (just the one screw not the ribbon beneath) Push the switch over to A. Hook the bottom of the plate back to the lens and put the screw back in. Done!
Jul 26, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Feb 10, 2009 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Putting it back together
In 1965 I did the same thing with a Nikon single focal length lens my F Photomic. This lens was far more simple then a modern AF zoom lens. I had to bite the bullet and pay a camera repair man to fix the lens. He told me that had I not tried to fix the lens myself, the repair would have cost 1/4. The only answer to your question is to take it to a camera repair man and get a quote. I would check the quote against the price of your lens on E-bay and use that to determine if you want to fix your lens or replace it.
By the way, it is very rare for dirt between elements to be so problematic that it results in a degradation of picture quality.
Aug 05, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Fuji Finepix S1 Pro fE E blinking when turned on?
Might Help:
Notes on G-type Nikkor and other CPU Nikkor lens
The G-type Nikkor lens has no aperture ring; aperture should be selected from camera body. Unlike other CPU Nikkor lenses, aperture does not need to be set to minimum (largest f-number). CPU Nikkor lenses other than G-type Nikkor lens have an aperture ring. Set the lens aperture to its minimum and lock. When the lens is not set to its minimum aperture setting and the power switch is turned on, "fEE" blinks in the control panel and viewfinder and the shutter cannot be released.
Nov 09, 2007 | Fuji FinePix S1 Pro Digital Camera
Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
579 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
