Question about Toshiba 32HL67 32 in. LCD Television
Tv turns on then picture goes black
The tv turns on for about three seconds then the picture goes away, but the sound is still working just fine.
  • Anonymous Dec 16, 2008
    I have the exact same problem with my 37" Toshiba LCD
  • 4 Answers
SOURCE: my tv has sound but no picture
If you haven't bricked this unit yet, or paid Syntax/Olevia's highway-robbery price to fix it (and pay STUPID prices to ship it to and fro), there is hope. Despite what Syntax and others say, it IS a replace-able part that can help get your TV to last at least another 12-24 months. During that time, you can save for a new, more reliable and reputable TV.
http://www.lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=V144-001
This is a well-known (at least those of us who had ours fail before yours) symptom of a bad backlight power inverter, which, for the LT30HV is a pain in the arse to get to (it's behind the main power distribution board and motherboard w/Pixelworks chip). If you can take apart a tower computer and install I/O cards, you can do this. These parts are made cheaply in China with 64 weld points that fail 100% of the time - and many other 'name' brand LCD TVs use this exact same CCFL backlight inverter. I'm working on posting the procedure somewhere on the net. The procedure shown in MoniServ's website is on a Kreisen set, which looks FAR more easily serviced than the LT30HV.
Good luck,
Posted on May 26, 2008
dsacco86
  • 1077 Answers
SOURCE: The picture blinks on for just a second, then goes
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 21 Answers
SOURCE: the screen goes complete blank with sound still
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 19 Answers
SOURCE: Picture great then goes black
has to do with the main board like the other guy said go to www.shopjimmy.com way cheap and its that one cuz was told to me by the manufacturer you call tv repair man they give you all this **** it can be the power supply or the main board bring it so we can tell you just to get the money for checking it out go to this site get it but be real careful with the screen you can do it your self i did mines aint no science.
Posted on Apr 17, 2010
budmrtn
  • 11361 Answers
SOURCE: westinghouse lcd has sound, works
Thre 24vdc power supply or backlight inverter boards may have gone out, those are the places you ned to check first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
Please read my guide to understand how LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 12, 2010
When i turn my snes on, the tv screen shows scrambled pictures of the game for a second and then goes black but the audio works just fine. the music continues playing. ive tried three different cords....
Well try cleaning the game packs out with qutips and rubbing alchoal it sounds lIke a glitch then that can occure sometimes with the old consoles
Nov 23, 2010 | Nintendo Super NES Console
The picture on my TV goes black after few seconds
Hi my name is Roety,
I can help you with your issue ,
Sounds like a lamp going bad
No model listed makes it hard to guess here
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Televison & Video
Big Black Square
It turns out that the Closed Caption option was turned on somehow. When I turned that off the Black Square went a way and did not return.
Sep 14, 2008 | RCA T19408 19 in. TV/VCR Combo
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Picture trouble
Good Day, britt93;
It sounds like you have the TV's CLOSE CAPTION on; in the text mode, turn off and you and the TV will be fine.
Good Luck, big IRISH.
Aug 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Toshiba 32HL67 32 in. LCD Television Logo
188 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
