Katadyn Kata CC-191 Shoulder Case KTCC191 Camcorder
Problem for Katadyn Kata CC-191 Shoulder Case KTCC191 Camcorder
My Camcorder won't power up when you turn it on, what can i do?
By Bouncy - usenet poster
Same Problem
May 22, 2009
-   My camcorder is not workin and i just got it
wen i try 2 turn it on it makes a beep sound and blinks red
HELP -   mini_angel_1
Oct 27, 2008
-   I have Panasonic VDRD210, used it approximately 12 times.  Battery died, camcorder shut off.  Never been able to start back up, plugged directly into wall, charged battery on multiple occassions.  Left alone for a week with no battery.  Tried again, still not working.  Even called panasonic but it'll cost me $111 to get it fixed (I  paid $198 for Camcorder).  ****.
I guess I'll try taking it apart, what have i got to lose?-   Guest
Aug 08, 2008
-   Camcorder freezes on 'Canon' start up screen when turning on to record. Freezes on this continues when turned 'off' - have to remove battery in order for it to turn off. Works fine in play mode.-   who_dya
Jul 12, 2008
-   i press the power button it comes on but doesnt stay on would it have anything to do with the small lithium battery?
-   Guest
May 10, 2008
-   Sony handycam on/off dial won't stay in on position. Tried new battery and charger base directly plugged into wall. (model DCR-SR300)-   Simpkin
Best Solution
posted on Mar 22, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It worked for me.
Solution #2
posted on Aug 08, 2005
Somewhat Helpful)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
Remove all power (including lithium batteries) for 30 seconds. Reinstall batteries, connect AC adapter and see if camera will reset. If not, it probably needs service.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Feb 02, 2008
Very Helpful)
Averia
Rank: Apprentice
Rating: 100%, 1 votes
Well, up until 2 minutes ago, I had the same problem.
If you hear something sliding back and forth in it, and you've tried replacing the battaries etc, then you might be having the same problem.
For mine, the "spring" [the inner support/connector] for one of the batteries got flattened down, probably from dropping in the batteries rather than sliding them in sideways. Because of this, one of the batteries was unable to touch the conductors on both ends. All I had to do was push the spring up until i could hold up the battery.
Unless you really think this is the case, I wouldn't suggest looking into this though, since I had opened mine up when I noticed this and it's the only way to access that. Well, I supposed you hook it with a loop of thread and try to pull it up some that way, but then you can't really be sure which is the problem, or if that even is the problem...
Good luck with your camera ^_^;
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Nov 14, 2008
Helpful)
rebecca23
Rank: Apprentice
Rating: 88%, 2 votes
I just posted a problem.  The camera made a beep and the power light started flashing.   It wouldn't power up or do anything.  I followed the advice above, unplugged the external battery charger and removed the battery pack.  It works again.  I feel silly that I didn't think of this.  First rule is unplug everything and restart..!  Thanks for the help!!
Was this helpful?
Yes
No
Solution #5
posted on May 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Panasonic NV-VX57 Mini DV Digital Camcorder - GIVING E 01 / E 02 AND U 02 error please help
Popular Solutions for Katadyn Kata CC-191 Shoulder
Questions and Unsolved Problems for Katadyn Kata CC-191 Shoulder
Do you recommend Katadyn Kata CC-191 Shoulder Case KTCC191 Camcorder?
Answer
Answer
pls.help me to get a software for my dcr trv265e camcoder.Presently i couldn't import video clips... (More)
Answer
what is the difference between 8mm and super 8 camcorders
Answer
it wont turn on so i charge it and it says its charging and after like days or more it wont turn on... (More)
9 Other Users Have The Same Problem - Continued
Comment by tomarcinas, posted on Apr 27, 2008
my dv 4100M turn on black screen on lcd, no power led indicator, what can i do? pls help me
Comment by Remeiam, posted on Mar 22, 2008
Will not turn on. Replaced batteries, Checked voltage, Depressed button that lcd screen hits. held menu button. nothing works!
Comment by Guest, posted on Mar 12, 2008
Acts like the battery is not charged
Comment by zeest, posted on Nov 21, 2007
Dear , hello
can u send me instruction book of this product because my handy cam wont get power or frnankly speaking i dont know any thing about this .,
Thanks
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorder Experts
Top Camera & Camcorder Repairmen
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
