Question about Garden
Ryobi Lawn Hornet Magneto Gap
Just replaced the maggie - what should the gap be between the maggie and the impellor?
Bob T
boscia
  • 163 Answers
SOURCE: set gap on magneto
use an index card or piece of manilla envelope
Posted on Nov 29, 2008
  • 211 Answers
SOURCE: I need to know the magneto gap for a 26cc Ryobi engine
Hi
0.35 mm
regards savumihai71
Posted on Jan 05, 2009
  • 708 Answers
SOURCE: Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Posted on Apr 29, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
bbreton
  • 437 Answers
SOURCE: Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Posted on Dec 16, 2009
Need magneto gap specifications between the flywheel and magneto.
I don't know the specs, but a business card inserted between the two always works for me.
Oct 12, 2014 | Garden
Good Day Mate
Dec 14, 2009 | Garden
I have a Briggs & Stratton Sovereign 375 engine model no 1OD902 type 0129B1 code 03012751. No spark at all - any ideas please. Had the flywheel off - that's as far as I got. Bob
Bob, if you have the flywheel back on, first check the air gap between the magneto (ignition armature) at the magnets on the flywheel (a common business card works well for this) then unplug the small wire from the magneto and check for spark, if you have spark, repair the kill switch and/or wire, if NO spark, replace the magneto.
If you remove the spark plug, you can hand spin the flywheel fast enough to ascertain spark
Oct 11, 2009 | Garden
Lawnboy gold series 10400, sn 4906038, failure to fire. Possible bad magneto. Looking for replacement part and magneto settings; i.e., gap between flywheel and the magneto. Any other tips appreciated.
You should be able to get a new magneto at any local lawnmower repair shop. The proper gap can be achieved using a standard business card. When you get the new mqagneto, turn the magnets on the flywheel to the opposite side away from the magneto, replace the magneto pulling it all the way back away from the flywheel and "snug" 1 or both of the mounting screws.
Now, turn the flywheel magnet to where it is centered under the magneto, insert the business card between the flywheel and magneto and loosen the screw you tightened earlier. Magneto will pull down tight to the magnet. Tighten both screws then rotate the flywheel to remove the business card
Sep 22, 2009 | Garden
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Magneto air gap for rover powermaster with east start motor
Hi magneto air gap is normally 10 thou but if there is no play in the top crank bearing you can close it up to 8 thou.
Jun 15, 2009 | Garden
Set gap on magneto
Sep 12, 2008 | Craftsman Convertible 25cc. Gas Line...
Garden Logo
451 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
