Question about HP OfficeJet 7410 All-In-One InkJet Printer
Hi, I have HP 7410 printer. but I believe there is a hole in wires that connect to Black cartridge. Do you have that parts for sale?
  • myclcc Dec 11, 2008
    I believe that the wire was broken. because I saw a hole.I need a new wire to replace.
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    How you say that there is a hole? do u experience Ink leaking from black cartridge???
  • 169 Answers
It's really hard to get a broken wire inside the print mechanism, so I suspect that something else is going on. Have you tried using a different ink cartridge? If a different cartridge does the same thing examine the holder where the ink cartridge inserts, sometimes a little bit of debris (dirt, tape.etc) can get on the pins that connect the printer to the cartridge.
Carl
Posted on Dec 10, 2008
My 7410 keeps saying to add a black ink cartridge but i did
Remove black cartridge and check to insure the spring has not broken loose.
Jan 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410
When you find out Jeff, I sure need to know too! Here's my story:
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place.
Mar 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp psc 2179 all in one
Please open the below link :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpu05206
Please copy the entire URL and paste it in a new window of Internet Explorer and press Enter.
Thanks.
Silan
Dec 22, 2007 | Office Equipment & Supplies
HP 7410
Sounds like a bad cartridge, you may want to try an original, it may be worth the cost instead of a new printer. First clean contacts on printer w/alcohool and put the cartridge back in. Not fixed try a new one may be worth the $40
Oct 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
