Question about Optoma EP716 Multimedia Projector
Dark or no image at all
I have the ep716 dlp projector it show about 808 hours. put now the brightness has faded from my picture. also with this projector i was always able to see a picture with lights on,but now with the lights on i can't see any images at all. if i attempt to adjust brightness control the picture in the dark is still not displaying as it should. please help
    Problem Solver:
  • 7 Answers
CHECK THE LAMP IF THE LAMP LUSTER HAS GONE OUT OR THE FILAMENT AT DOWN PORTION IS BLACK THEN THIS PROBLEM HAPPEN
Posted on Jan 30, 2009
  • Eddie Dominguez Apr 29, 2013
    How do I check the lamp luster? Opening up the projector?
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
The image projected is dull and colors poorly shown, Photos are not bright and vivid. How do I clean the machine inside? It's about 4 years old and has been well used but with care. Many thanks.
If the lamp has had many hours of use , this could be a reason why the picture is poor.
Has there been much dust collected in the filters over the years.
Jul 09, 2011 | Dell 2300MP DLP Projector Multimedia...
Proxima DT 5800 works but picture is much brighter with the lights out ,what could cause to be not as bright with lights on?
The Proxima DP5800 projector is a small format low powered projector at only 650 lumens (brightness measurement). It simply doesn't have enough lumens to cut through ambient light and display a clean image. It is best used in a dark room.
Also bulb age will play a factor in overall brightness. The lamps for that projector are only rated for 700 hours, and as they near the life expectancy they can lose up to 50% of their lumens.
Mar 09, 2011 | Office Equipment & Supplies
Our picture is faded and the brightness is completely washed out the bulb has 1000 hrs on it does it need to be replaced?
yes it certainly seems like. the DLP engine won't have any age related issues, which means it must be the bulb.
I realize that 1000 is not what you'd expect for a bulb, but frequently manufacturers quote bulb hours on diminshed or even minimal settings.
bulbs are available for much cheaper online, even some reputable dealers on ebay. Just be sure to check their feedback!
Mar 03, 2011 | ViewSonic PJ402D DLP Projector
Optoma projector Ex350 connect to xbox360
buy a new projector i recommend sanyo projector specially model XT35... cause your projector is not compatible to your xbox.
Oct 06, 2009 | Optoma EP716 Multimedia Projector
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Ihave a sony KDF-E50A10 and the picture is fading
check the lamp timer in the menu page of the projector.it it is more than 1500 hours, it can be the lamp
alternativly u may also check the optical engine as it may be covered with dusty , hence resulting in dull images
Feb 06, 2009 | Sony (XL-2400) Projector Lamp for...
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
OPTOMA EP716
ALSO CHECK YOUR FAN. IF THE FAN OR A HEAT SINK IS NOT WORKING PROPERLY (I.E. THE FAN MAY JUST NEED TO BE CLEANED OR REPLACED, THERE SHOULD BE A SMALL HEAT SINK. IF CLOUDED W/DUST, IT WILL KEEP THE OPERATION SHORT). ALSO CHECK IF YOU HAVE SET ANY TEMPERATURE SHUTDOWN PARAMETERS. IF YOUR LAMP HEATS UP FOR SO LONG AND REACHES A TEMPERATURE THAT WILL AFFECT THE CIRCUITS, THIS OF COURSE WILL SHUT DOWN YOUR UNIT UNEXPECTEDLY. HOPE THIS HELPS...JGUAM
Jan 12, 2008 | Optoma EP716 Multimedia Projector
Why is my projection dark and muddy compared to the brightness on my computer screen?
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
May 03, 2007 | Dell 1100MP DLP Projector Multimedia...
Optoma EP716 Multimedia Projector Logo
243 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
