Question about Canon S 9000 InkJet Photo Printer
Error message no paper
Hi. This error "no paper" appears randomly. Earlier, when I used to place up to 4 sheets in the printer to print all odd page numbers, then turn them over for the even numbers, it would occurr - but I thought maybe a computer glitch. Now I print only one sheet at a time becuase of the problem - and it still appears even when set to print only one sheet... Hope you have a solution, GeTe
kristy22
  • 4 Answers
SOURCE: canon HL 5040 printer grabs multiple papers to print
try one sheet at a time that may work.
Posted on Oct 21, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Cannon MP600 error message U052
hi there,
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
Posted on Jan 16, 2009
moto34
  • 155 Answers
SOURCE: Canon i9950 inkjet printer, keeps showing paper
Maybe it's just one small paper.
If it's on guarantee, take it to store, and describe the problem like this:
"Cant print. Don't know whats going on!"
So they don't charge you ;)
If it's out of guarantee, try to open all parts until you see the small paper.
Or it could be the sensor (piece of plastic) that was jammed, or get jammed when paper pass. Take a good look on that too.
Posted on Aug 27, 2009
Testimonial: "Will take a look, I think I will need to dismantle it and give it a good check through. I have been quoted £150+ to repair/clean it."
  • 117 Answers
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Posted on Oct 09, 2009
SOURCE: the sheet feeder of the canon IP880 doesn't work properly
my printer also goes like that..what do you mean by cleaning? opening the printer?
Posted on Jun 21, 2010
The printer will pause after the even numbered pages have printed. follow the instructions below to print the odd-numbered pages (second sides)
The Printer is waiting for you to remove the printed sheets and turn them over and put back in the printer so it can print the odd number sheets on the back.
Oct 29, 2018 | The Office Equipment & Supplies
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
May 12, 2011 | HP P4515n LaserJet Printer
Canon mp600 printer repeated error code 6B00
After reading through earlier problem fixes, I inserted a piece of Card right through the feed system then taped all the covers and loose paper feed trays closed with masking tape. Picked the whole unit up, turned it upside down and shook it up and down and side to side quite hard. Put it back in place on the desk, undid all the tape and plugged both cable back in and switched it on. It went through a long startup process, spat out the card sheet and has worked OK since then (about 15 sheets printed).
Thanks for all the ideas in earlier fixes.
Nov 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
Paper mismatch error
I got around this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon S 9000 InkJet Photo Printer Logo
Clive
Clive
old marine
old marine
