Question about SAMTRON 55V 15" CRT Monitor
About colors my monitor is not displaying the red color. When i shake my monitor then it starts showing the red color else red color comes in gray.
  • Anonymous Mar 22, 2014
    The color red doesn't work. other colors show fine.
    Scholar:
  • 135 Answers
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Posted on Feb 21, 2007
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
No red color displayed
If all software setting done perfectly but till color problem in your monitor, then need to call monitor technician. It may occur from crt neck base loose contact or bad contact. need to replace new one.
normally no need to discharge crt capacitor for repairing dry soldering.
Apr 10, 2012 | LG Studioworks E700S 17" CRT Monitor
Hi, I have a samsung samtron 55V 15 inch monitor. The problem is it is not displaying the actual colors. The red color appears as a greenish/bluish shade. Ex: The Windows Start button is showing as light...
You have to check for dry soldering in the base board of you mointor. The base board is on which is attached to the picture tube neck. In most cases there will be dry soldering in the pins of cathode diver ic in that base board. It will be difficult find out which pin have the dry soldering. Do on thing resolder all the pins of that ic. This ic cotrols the three cathodes of picture tube (red, blue, and geen) is any one did not get the correct drive that color will fail to display. In your case the red cathode is not getting the drive voltage. Thats why it shows only gree and blue. This is a reular complait for crt monitors.
ok
Jul 17, 2011 | SAMTRON 55V 15" CRT Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor is not showing red colors? how do i fix
There is a number of possible reasons why your monitor lost the red color. A good guess, however, is a broken cable or connector. Check the plug and socket of the cable for bend or broken pins. If everything looks OK, try to change for a different cable.
If the problem persists, a pin of the connector soldered to the PCB internally may be broken. This is an easy repair for a service technician but I really recommend you do not do it yourself.
Feb 05, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My monitor will drop the colors
check wheather is there any land phones are there, or any sound speakers present beside the moniotr.
than also not working give the monitor to repair.yes it is fixable.
Jul 17, 2009 | HP Computers & Internet
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
1 monitor is red - 1 is green
its because when you start putting to many moniter spliters the color data gets lost in the link.
Sep 12, 2008 | Matrox 128 MB G450 Quad Graphic Card
SAMTRON 55V 15" CRT Monitor Logo
71 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
