Question about HP Computers & Internet
Hp system board
I have hp pavilion t220i.will dual core work on it and does it support ddr2 ram.if dual works on it then which version is best!!
  • 395 Answers
The machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Posted on Dec 08, 2008
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
I am looking to get a new hard drive for my pc.
Add more ram is it uses a lot of graphics it might be slow adding more Computer ram will make it faster.
HP Pavilion a6228x Computer Memory.
The HP Pavilion a6228x Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2 Memory Type, and comes installed with 2.0 GB (removable) of Memory.
You can upgrade your HP Pavilion a6228x Computer to up to a maximum memory capacity of 8.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB (removable) standard memory installed.
For best Pavilion a6228x Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use theCrucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible
Dec 26, 2013 | HP Pavilion a6228x PC Desktop
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
Dual core E2160 1.8ghz doesnot display actual speed
i think the reason for not using 800fsb is your memory. make sure that you use ram that supports 800 fsb (ddr2-800).
as i don't have the manual i describe you another problem that may be the reason if you already use ddr2-800 ram -> on some mainboards the fsb is rated down when a defined level of memory built in is reached. please check your manual if your board has such a limitation.
Jul 26, 2009 | Biostar P4M890-M7 Motherboard
No display
Beep codes are usualy heard when there is a problem with either your display card or your RAM.
Your problem could possibly be a faulty CPU.
Does your CPU work in another board, or can you try another CPU in your board?
Regards,
Graemevm
Apr 23, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
Gta- iv is not working in my pc
GTA IV is a very poorly coded game and has trouble running on even some of the best PC's.  Do you have 2gigs of RAM and 280MB free?  Either way, you will certainly need a very very good video card to play this game.  What video card do you have now?  Did the game work before you installed vista ultimate?  Is the game also pirated?  If so it's quite possible you downloaded a bad version.
Apr 21, 2009 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Computer ram
Best Solution
Hewlett Packard Pavilion 503w Memory Maximum Memory 2GB Memory Slots to 2 Slots. non-removable base memory 0MB Your HP Memory Pavilion 503w only supports modules made with a specific type of chip build. If you come across a website and find what seems to be the exact same memory for a lower price, it is likely that the cheaper memory will not work in your system.
use :1GB DDR2
Thanks and Regard
Dilip Bagdi - contact me at - johny_inmexico@yahoo.com
May 11, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
