Question about Garden
Honda snowblower engine hunting
I have a honda hs 724 snowblower.Last year the motor ran fine this year I start it and the motors rpms go up and down at high speed.Is there an ajustment for this.Ive taken the carb off dissasembled and cleaned it but it still does it.
  • klkst Feb 22, 2009
    I have a Honda 1132 snowblower with the same problum I have tryed to adjust the governor with no luck have you had any luck fixing your 724
  • 49 Answers
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Posted on Feb 03, 2009
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
Idle up down
hunting or surging ilde. name the 2 RPMS, low and high , is it hot or cold engine this issue.? 400rpm or 1000 or 2000 all are diff.causes.
no year, stated. so cant help.
but ill answer in the generic,
1: the ECU (got a carb,? )
the ecu controls idle speed at all times.
if not , there is a problem (you)
A: air leaks in the induction will make motor race at some point the ECU/ISC loses control. and hunts. trying hard to correct it.
b: egr stuck open idle too low, iSC cant correct it,, bad EGR.
c: engine EFI running way too leak starving for fuel so it hunts for 2 reasons < ISC hunting, and lean does that.
lean is gross power loss and opening throttle bogs the engine.
so is double bad. ISC makes it worse,
all this breaks down to 2 reasons.
1: ISC bad. in some way (gummed up. or restricted inside)
2: bad fueling or air leaks. vacuum leaks.
try answers , the hot cold question and the 2 speeds, of the hunt.
lowest rpm and highest of the hunted range of RPM.
Nov 23, 2013 | Honda Civic Cars & Trucks
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
Ran the engine way too hard
Most of the time when this happends it has to do with valve train like broken valve spring, or bent valve , or even a bent push rod or colapes lifter, or rocker arm. At any rate i think your problem is in the valve train.
May 26, 2009 | 1994 Chevrolet Cavalier
Honda snowblower problem
yes you can adjust the throttle cable, did you leave gas in it over the season, if you did this is definitley the problem, dump out the gas and pour new.
Feb 25, 2009 | Garden
Toro 724 snowblower won't start
One of two things will cause this. Either your piston rings have fried and your piston is stuck. The bearing on the flywheel is bad. Or actually one of thing, the crank shaft has broken. You willl need to take the motor apart all the way and see what is going on. If you take the flywheel off try to turn it by hand and see if you can turn it that wy. You also can try easier to check for first symptom is to make sure you are not in vapor lock. Remove the spark plug, turn unit upside down and see if you can get the motor to turn, if you can then replace the spark plug and it will start up. You can getvapor lock by running it low on fuel or the wrong fuel or running it to rich
Feb 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Rpms up and down/idlind
hey
il give you a list of problems it could be...its a problem that could come from a wide range of sensors etc
try changing your TPS (throttle positioning sensor) its located on the intake area (look where the throttle cable hooks to the engine) Possibility of a fuel pressure regulator problem. Also a faulty Idle Air Control motor (IAC) could cause the problem. computer may need to be reset. (disconnect the battery for bout 15 mins) possibly a vacuum leak...check hoses, you may need to replace your intake maniflod gasket
Sep 08, 2008 | 1994 Honda Civic
Garden Logo
615 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
