Question about Kitchen Ranges
Replace worn gasket on self cleaning oven door
Worn gasket K132811 needs to be replaced by gasket 5303051704, frigidaire part for Electrolux Home Products White Westinghouse self cleaning oven (stove) model KF450G DDO. instructions to remove worn oven door gasket. instructions and product needed to install replacement gasket. I have the replacement gasket 5303051704. White Westinghouse electric stove with self cleaning oven.
ndguy2481
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
SOURCE: westinghouse self cleaning oven manual or owners manual
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Posted on Feb 08, 2008
  • 150 Answers
SOURCE: Frigidaire stove door looked
temp was too high or the sensor smoked. this happens, self clean wreaks havoc with the electronics on this stuff. need your model to tell you what the error code means
Posted on May 10, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
SOURCE: How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Posted on Jan 23, 2009
Frigidaire Oven door wont open after self clean cool down
Good Morning Marlyn Allen, thanks for your post!
Based off the information you have provided your Frigidaire oven door will not open after it has cooled down. I would hold down the clear or cancel button for ten seconds that should release the door. If that does not work I would perform a reset on your oven and you can do that by disconnecting the power from it for approximately ten minutes. You can also perform another self-cleaning cycle and before it starts cancel the self-cleaning and then wait for ten seconds and the door should release. If you follow these steps and the door does not open it could be a faulty door latch and that would need to be replaced by a technician. Best of luck! -Matt
Dec 12, 2014 | Frigidaire Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Door does not close all the way
    Good Morning Richard, thank you for allowing me to assist you!
    If the door does not close all the way, there is a possibly that the issue lies with either the door gasket or the hinges. The door gasket may be worn or torn and the hinges may need to be adjusted or if they are too damaged, possibly replace. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
    Dec 16, 2013 | Frigidaire 30 in. Electric Gallery Series...
    I have a Frigidaire Electrolux Model FEB30S5ABB. The oven will not heat up to the correct temperature and the bottom element is not turning on. We checked the element at it checks out ok. What could be...
    Hello lizzyd62 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately.
    Nov 23, 2012 | Frigidaire 30 in. Electric Single...
    I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
    If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
    Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
    I have a frigidaire Electrolux self cleaning convection oven. I put it on self clean and it went fo over ten hours. now the door is locked and I cant open it. I tried to self clean and it wont start. The...
    These ovens have notoriously bad control panel electronics. There is one control board for the oven that can be replaced or sent out for repair, $100 to $300.
    Feb 03, 2018 | Frigidaire Ovens
    Turned the oven on and heard something pop behind the stove and realized neither of the two oven elements would come on. The top 4 burners all work. It is a Frigidaire- Self Cleaning Mod.-...
    there is a chance that one of the wires has burnt to the baking element. you will need to pull the unit out unplug it and remove the back panel. and check the wiring if it is burnt you can replace the burnt part so long as there is not to much destroyed you may have to add a piece of new wire.
    you can use regular but connectors and spade connectors to replace the bad parts.
    Mar 03, 2011 | Frigidaire Kitchen Ranges
    The self-cleaning cycle on our oven stops mid-cycle
    I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
    Check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Mar 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Aft self-cleaning, top of oven door and knob panel discolored
    This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
    Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
    Cannot unlock oven frigidaire electrolux gallery series
    Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
    Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Kitchen Ranges Logo
    767 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
