Question about Sewing Machines
Singer sewing machine #6268 Bobbin winding not working
I have a Singer sewing machine #6268 and the bobbin wind is not working. I did find a small stop in the machine. The only place I could find where it goes is on the back side of the slide plate. Is is OK to super glue it one.
  • joyv Dec 13, 2008
    Hoping someone can help me too! I have an older Singer #6268 and am having a lot of trouble winding a bobbin. Sometimes it works, but most of the time it doesn't and I can spend a lot of time with this. Today I opened the machine up, took needle plate off and can see a little assembly which can be adjusted by a screw. I have loosened the screw and moved it around in many postitions but I would like to know where it needs to be in order to wind or if something needs replacing. It seems to me it needs adjusting, but how? Thanks for looking. Joy
  • Anonymous Mar 13, 2009
    not sure what i'm doing. need help bad.
    New Friend:
First you must clean the bobbin chase, remove all lint and threads. After you have cleaned that area, reset your screws (assuming you adjusted the screws on the bobbin case and not something else). Re-thread you upper thread and make sure the pressure foot and needle are in the highest position and you are in straight stitch mode. Then install an empty bobbin and push the cover so the arrows match (you should hear a slight click). Pull the upper thread down and wind it over the presser foot screw, insuring you are on the little area DIRECTLY BEHIND THE SCREW, pulling thread under the pressure foot before winding the thread. Press "A" button and the circle with the dot in the middle should light up. The just press on the foot pedal. You can see through the view port how the thread is winding the bobbin.
Posted on Jul 13, 2013
    Genius:
  • 1,199 Answers
Yes but less means more
Posted on Dec 08, 2008
4 Suggested Answers
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
Singer 6268 bobbin winding
I've never seen this type of winding system. But from the manual on page 10, it shows that in order to disengage the machine from sewing mode.. you need to have the bobbin cover slide plate slightly open.
http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf
Also make sure that your bobbin doesn't have any burrs. If it does, toss it and use a new one.
Jul 21, 2012 | Singer Sewing Machines
I have a Singer 6268. When I try to load the bobbin, the thread winds underneath the bobbin instead. What can I do to fix this?
change the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
make sure there is no burrs on the bobbin case or that the bobbin
case is not damaged
if none of these suggestions help, then it might be a good idea
to take the machine in to be check at a sewing machine shop
May 31, 2012 | Singer Quantum XL-6000 Computerized Sewing...
Singer 6268
Here you go:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_6268_threading_diagram.htm
May 25, 2008 | Sewing Machines
Sewing Machines Logo
463 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
