Installed per directions but realized that the directions all indicate a right handed door. Operation is backwards. There are no Door Handed jumper switches noticable as per your prior instructions for a Power Bolt. Latch Cylinder is labeleled clearly with 'up' indication, but in lieu of any other obvious options, can I simply turn tis upside down and have any success? Will it even line up?
In section 8 of your instructions is the "Door handing" programming instructions
Link here: http://s7d5.scene7.com/is/content/BDHHI/Website%20Content/Kwikset/Resources/KwiksetSmartCodeManual.pdf
You need to carefully go through this programming routine without interruption. That should fix it for you. Good luck!
SOURCE: kwikset keyless entry is backwards
The config terminal is wrong. Take the cover off and move the 2 pin terminal over one pin.
SOURCE: how to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
8. Changing the password code: - please follow these instructions:
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
These stept will program only the new code you enter for your unit.
SOURCE: H do I reset all
This link will take you to the PDF image of the installation and programming instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
(PDF files require that you have Adobe Reader or similar installed on your computer
http://get.adobe.com/reader/ )
It's a good time to replace the batteries while you're reprogramming. Please review each step carefully, because it's easy to goof up this programming process, if you don't follow the procedure properly.
SOURCE: Just installed kwikset 909 all
For your review, here is a link to the installation instructions for your lock:
Under the Troubleshooting steps at the bottom, you will see this text:
Q: I just completed the installation of a Smart Code unit on my door; I am unable to operate it manually, although I checked for smooth bolt operation during installation. What should I do?
A: You need to run the "Bolt Direction" routine again; allow the process to run to completion see Section 8 in User's Manual.
So please go through the installation instruction's Section 8 again. (Remove the battery pack first.) It is important to follow this procedure very carefully for success!
If you feel that you are following all steps correctly but the lock is still not functioning properly, please contact the Kwikset Customer Support:
Call: 1-800-327-LOCK (5625)
SOURCE: The backlights on our Kwikset 909 are not lit. Is
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
