Question about JVC HR-S9800 S-VHS VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
Tape runs fine but when I try to eject tape, the machine makes a noise and then the power turns off. Any suggestions?
    Genius:
  • 1,199 Answers
This sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Posted on Dec 08, 2008
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
JVC HR-S9500 S-VHS VCR. all functions work except the eject on the vcr. there is no eject on the remote.it plays, ff, rew, stops etc. I can't get the tape out.
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Jan 05, 2010 | JVC HR-S9500 S-VHS VCR
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Mar 11, 2009 | JVC Televison & Video
Problem ejecting tapes getting stuck
The take up is not rewinding the tape all the way back into the shell. Check the idler, it's either worn or if it's plastic it is warped from the heat.
Feb 09, 2009 | JVC HR-S6600 S-VHS VCR
Ejects tape as requested, then pulls it back into unit
Its not fully ejecting the tape. Return it or get it repaired, you can try to do it yourself but isn't recommended.
Feb 04, 2009 | JVC HR-A592U S-VHS VCR
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
JVC HR A62U VCR
I was wondering if you tryed unplugging vcr for an hour then
plugging it back up. sometimes this resits it and it will work fine.
the tape might eject itself out or eject button might work.
Nov 10, 2007 | JVC HR-A32 VHS VCR
JVC HR-S9800 S-VHS VCR Logo
142 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
