Question about Logitech X-530 Computer Speakers
Logitech x-530 speaker problem
I recently purchased a set of Logitech x-530 speakers. When I plug the speakers into my computer, the sound is really muffled and anytime I turn up the volume, the muffled sound gets worse. I had a decent set of speakers already on the computer and they worked well so I'm not quite sure what the problem could be except that the speakers might be screwed? Thanks for any help
  • 944 Answers
Try going through this troubleshooting procedure site first: http://logitech-en-amr.custhelp.com/cgi-...*uWZ8vi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1 If you get no solution from this, there are other similar logitech speaker systems that have had similar problems on initial models. it appears that logitech have been very helpful with replacing speakers in the past if design or product is faulty. Give them a try. hope this helps:)
Posted on Feb 28, 2007
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
I recently needed to reboot my computer back to factory setting due to what I figure was a virus now my speakers won't work. I have speakers labeled Logitech X-530 do I need a disk to add this as new...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 07, 2010 | Logitech X-530 Computer Speakers
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Apr 03, 2010 | Logitech X-530 Computer Speakers
Not all speakers work
http://www.logitech.com/index.cfm/439/3549&cl=us,en?WT.ac=sc|downloads||dd
Jan 13, 2009 | Logitech X-530 Computer Speakers
Sound mostly out of one speaker
my spearker will not work it saids audio default
Dec 06, 2008 | Logitech X-530 Computer Speakers
I can`t get any sound.
double click the speaker on your taskbar and select the volume
Dec 02, 2007 | Logitech X-530 Computer Speakers
There should be a setting in your sound card, assuming it is a 5.1 surround card, that allows the card to split the signal from two input connections (normally the normal speaker input'green' and the mic input'pink')into the required 5.1 output.
Feb 08, 2007 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
318 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
