Question about Nikon ?? 3 - 9x40 mm APG Omega Muzzleloading BDC - 250 Reticle Riflescope
Elevation knob is topped out i still need to go up about 5"
Im sighting in a new bdc 250 on a thompson center encore it is shooting 4" to 6" low and the elevation knob is topped out and will not let me bring the sight higher what do i do
  • cutlassguy
    cutlassguy May 11, 2010
    if you are shooting low shouldn't you move the elevation down? Sometimes you can tap lightly on the adjustments to seat the screws. What yardage are you sighting in at?
  • 117 Answers
Remove the top of the rear scope ring and place a plastic shim UNDER the scope.I use plastic because it is impervious to weather.I usually use clear plastic from a blister pak but even a shim cut from a plastic milk jug will work.I just cut it to size with a pair of scissors.I have done this many times to correct for the mismatch in the height of the rings.
Posted on Mar 25, 2009
How Do I adjust the sights on my savage 64 LR its shooting High and its brand new
The rear sight has an elevation adjustment that looks like a stepped wedge. To lower the point of impact, you must lower the rear sight. If you have additional steps on the low end of the elevator, make the adjustment by slightly springing the sight up and sliding the elevator to a lower step. If you're on the bottom step, you can get a taller blade for the front sight (preferred) or file the notch deeper into the wedge. Try different types of ammo before making permanent changes. Guns can be picky about their diet.
Dec 12, 2014 | Optics
I have the thompson center muzzleloader trumiph.Having trouble sighting it in,shooting thompson tc bullets 250grain shockwave. with 2 triple 7 pellets and triple 7 209 primer. shoot and hit bulleye...
One thing about muzzle loaders, you should wipe or clean the bore after each shot. You need to find a method that works for you. I have an old CVA and I have to wipe the bore after each shot to keep it accurate, if shooting for fun I do not. But I would use my rod and with one patch in and out just to keep the fowling down.
Lets think of it this way. Even with the new powers they tend to build up. Now this build up causes each shot to have a different pressure and then each shot will run down the bore different. Hence one shot here another there.
Then there is the primer itself, The 209 primer has a very hot flame and can cause a bit of fouling.
See this link. Primers cause accuracy problems. It may help you understand what is going on. But the easy fix is to learn; wipe the bore after each shot. Use the same method to load powder, press the bullet in the bore, seat the bullet on the powder pellets, fire the gun, wipe the bore, start over doing the same steps, same motion, same pressure each time.
Jan 09, 2011 | Thomson Thompson Center Muzzleloader Rifle...
New nikon monarch III 4-16x42bdc. elevation is mased at lowest set still bore sighting at 2.25 above 0 with windage centered. actual shot is off target.
have you shot it yet???? dont forget bullet drop!!!! but if it shoots to hight thats easy to put right,,,most of the time its a mount fault, but undo the front of the scope mount and slid 3 bits of 35mm film under the scope then nip the scope down on the film strips,,this will lift the point of aim past what you need,,,,
Oct 05, 2010 | Nikon ® Team Primos® 3 - 9x40 mm BDC Rifle...
I zeroed in my 25/06 at 100 yards. at 200 yards 1/4 inch high using 2nd line on drop compensator , at 300 yards shot 41/2 inches high using 3rd line on compensator. What am I ding wrong
It sounds good to me, don't forget, the 25-06 is a flat shooting round, you have your scope pointing up, the bullet crosses the line of sight twice, One at 100 yrds, your zero and the other on it's way down at about 500 yards. You can check the ballistic coefficient of that bullet and see where you need to be zeroing it in at. I would think about 250 yards, will be 1 1/2 low at 100 yards, 3/4 inches low at 200 yards, dead on at 250, then it will start coming down, say 8 inches low at 400 and 18 inches low at 500. Something like that. So your BDC will not be needed till you reach out past 300 yards, which is varmint country stuff. I have my .22 marlin sighted in at 100 yards, and it will put the lights out on anything at that range. You can probably find the charts on line someplace, if you don't have a reloading manual. Check it out.
Jul 12, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
How do I adjust the elevation?
I suggest that you, consult the manufactures model to rectify the issue
Dec 20, 2009 | Barska Optics Barska Varmint Riflescope...
I have a bsa rd30 red dot scope. I am very confused. it is shooting in the middle but low. how do i raise it so it shoots center
there are knobs on the top and side of the scope, unscrew the black cover to them and you use a screwdriver to turn the knob to adjust it
Oct 18, 2009 | Optics
Scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Cannot sight in riflescope for elevation, adjustment is maxed out
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
Feb 01, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Which knob for elevation/vertical adjustment?
usually side. best thing to do is go to an indoor range and sight it in. Just know the ballistic for the round/weapon you are shooting. ie. An M-16 has the same trajectory at 36 yds as 300, that way you can sight in at 36yds.
Dec 13, 2008 | Nikon ProStaff Rifle Scopes
Instruction manual for 1970's custom .22 scope with BDC
Hold the outer portion of the elevation knob and unscrew the screw on top. then pull up on the outer portion and you'll see a silver screw marked with an arrow and the word "Up". Sight the rifle at a known distance and then line up the knob with that distance as you push it down on the scope and replace the screw. I have one of these and figured this out on my own, however I'm missing the mount and would like some pictures and dimensions of the mount if any of you can get some. I'm gonna be machining a new one and would like to keep it as close to the original as possible.
Sep 08, 2008 | Optics
Nikon ?? 3 - 9x40 mm APG Omega Muzzleloading BDC - 250 Reticle Riflescope Logo
376 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
