Question about Barska Optics Barska 10-40x50 Ir Swat Tactical Riflescope Ac10550
Just bought used 8x32 swat not sure how to use it. are the win and elev numbers for shooting or just for siteing in rifle
  • 117 Answers
They are for sighting in the rifle only.I know on TV the shooter reaches up and turns a knob.BOGUS! after sighting in the rifle, always replace the little caps because the scope is not sealed unless the caps are on.without the caps, moisture can penetrate the scope and fog the lenses.Good Luck
Posted on Mar 25, 2009
My Bushnell Banner rifle scope 3x9x40 ia at max elevation and shoots low The scope is used on a marlin 1894c underlever rifle and attached to a weaver rail how can i fix this problem
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
Feb 27, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I inadvertantly changed my elevation adsjustment.
this is an excellent article on zeroing a scope.
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Apr 06, 2010 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
I run out of elevation when mounting a scope to my Mini 14. What can I do? I cannot bore site the scope because the elevation maxes out. I use a Leupold boresite device. At the range the gun shoots low,...
this is not that uncommon when mounting a scope on a rifle, the way to get around it is easy
find yourself a strip of old camera film (35mm) cut a strip off and slip it under the eye end of your scope then nip up the top mount this will drop the point of aim in the scope, i use this every time i have this happen to the guys at my club but dont try to put more that say 3 strips of film under the scope or you wont get it to shoot down low,,,
Jan 06, 2010 | Optics
How do I adjust the elevation?
I suggest that you, consult the manufactures model to rectify the issue
Dec 20, 2009 | Barska Optics Barska Varmint Riflescope...
I bought a used scope with no manual. On the front of the scope it turns like the back but it has ranges on it do I need to know what range I am shooting for the rifle to be accurite
Take the bolt out of the rifle so you can sight down the barrel to the target. Get the target bullseye in the center of the barrel. Now look through the scope to see where it is. Adjust the windage and elevation screws to get the cross hairs on the bullseye. Look through the barrel several times to make sure the gun did not move off the target during the adjustments. A concrete bench with sandbags is best to use for this.
Dec 05, 2009 | Burris Fullfield II Riflescope
I just bought a rifle with one on it. exactly how
the adjustment on the front eye PC is your zoom.
for your wind edge you have a series of numbers.
some scopes differ some read 5,10,15,etc
some read 1,2,3,4 etc, the # are estimated wind speed,left or right.if the wind isn't blowing set it on 0.
for your elevation you will have a series of #'s
50,75,100,etc.this is your yard edge sight it in at 75 yrd's and if what your shooting at is 100 yards just turn the knob to the correct setting.good luck
Oct 30, 2009 | Bausch and Lomb Bausch & Lomb Hunting...
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
8x32 swat scope
It's not a high end scope. Most times you're better off buying a lower power scope of better quality and you'll still be able to see more clearly than with a higher power yet lower quality scope.
Consider that 6x, and lower power, scopes were pretty much standard for WWII snipers, and that fixed 10x is still an accepted power level for snipers these days.
Nov 04, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
How do u reset a rifle scope
Hi type into Google, Zeroing a Telescopic Rifle site, Shooters have there own ways of doing it but you will find what is best for you depending on what type of rifle you will be using. If you are fitting it to a Air Rifle. You could Type in Zeroing telescopic site for Air Rifles.
Hope this helps
Oct 07, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Barska Optics Barska 10-40x50 Ir Swat Tactical Riflescope Ac10550 Logo
174 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
