Question about Sony Cyber-Shot DSC-P92 Digital Camera
When i turn on my camera it blinks E:92:00 until i press the
Reset button and than i have to reset the clock and the date each time i take pictures. when i turn the camera off and turn it back on i have to started all over again
  • 88 Answers
Found this on the net : The problem is the battery isn't making a good enough contact. After you put the battery in, place a dime on top of it and shut the battery door - This should resolve your issue. Let me know how it goes!
Posted on Jan 12, 2009
How Do I Reset Date/Time on a Stealth Cam STC-U732IRNG?
SET TIME AND DATE:
1. Switch the camera to the ON position.
2. Press the [MENU] button to enter menu settings screen.
3. Press the [UP] or [DN] button until the word PIR blinking.
4. Press the [OK] button to confirm.
5. Press the [UP] or [DN] button to scroll through different setting modes
until the word TIME blinking.
6. Press the [OK] button to choose the Time settings.
7. Press the [UP] or [DN] button to adjust the Minute setting and press [OK]
to confirm and move to the Hour setting.
8. Repeat to set Hour and then press [OK] to confirm and move to Date.
9. Adjust the Month, Day and Year by using [UP] or [DN] button. Each time
you finish an adjustment you must press the [OK] button to confirm and
move to the next field for adjustment.
10.Once done, the word - dEL - will be blinking.
11. Press the [MENU] button to exit and start using.
Nov 16, 2014 | Cameras
Can I get rid of the date from my pictures?
To turn on or off the Date and Time stamp features, push the menu button. It's the small silver button on the back panel directly beneath the printed letter M, and just above the little green LED. This opens the menu. Now, press the right side of the ring shaped control button, where the little lightning arrow is. This will scroll through the different menu categories. Keep scrolling until you get to the one at the far right of the screen. It is a blue icon that looks like an envelope and a clock. This will bring up the menu for toggling the Date and Time stamp. Use the top and bottom of the ring to select the setting you want, and press the button in the middle of the ring, marked SET DISP, to select it. Then press the menu button again to get out of the menu and return to taking pictures.
Jan 20, 2011 | Polaroid i830 Digital Camera
How do I turn off my red blinking clock?
This is probably as a result of not setting the date and time. When the date and time is set, the blinking should stop.
That is a reminder for you to set the camera's time and date, so that each picture of other file will have a date when it was taken.
Oct 29, 2010 | Nikon COOLPIX L100 Digital Camera
URGENT PLEEEEEEEAAAASE
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
regards,
Luwangula
Sep 16, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
How do I set my clock on my Sony cameras DSC-p32
setting date and time on sony p32: 1)set the mode selector to photo mode
2)press power button to turn on the camera
3)select the desired date format and press ok/set button.
For more detailed pictured procedure click the link below :
http://www.retrevo.com/r/202bh150/11/Setting+the+date+and+time#q=Sony+DSC-P72
thanks.
Aug 28, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Jul 20, 2009 | Canon PowerShot SD870 IS Digital Camera
Setting date on Canon elph Jr.
To set the date:
1. Press the Date button (rear left button on top of the camera)
2. Press the Select button (small round button up and to right of date button, may need pen point to press), display may show 97 1 1, with the 97 blinking.
3. Press the Set button (below the Select button) to change the value of the blinking character.
4. Press the Select button again to change to the next character. Use Set again to change. Repeat until date is set.
5. Press the Select button when all characters are set.
To set time, press the Date button again and the display should change to time (24 hour mode). Use the Select and Set buttons as above to set the correct time.
C, H, and P indicate the type of picture you want to take. C stands for Classic, and the picture will be in a standard aspect ratio. H is the wide angle setting, and the printed picture will be printed wide angle. P is panoramic, and the printed picture will be even wider angle than H. All this depends on the processor who develops your pictures for you. Ask if their equipment can read and process according to the instructions your camera will automatically put on each exposure on your film.
The three buttons on the left side are:
Top -- Flash setting. On (lightning bolt) or Off (lightning bolt with line through it).
Middle -- Film rewind button. Film should rewind automatically when fully exposed, but you can rewind before the film is fully exposed by using this button.
Bottom -- Self timer. Pressing this button puts a clock symbol on the display. When this is set, the shutter will delay 10 seconds after the shutter button is pressed. Press this button a second time to turn off the self timer.
Mar 17, 2009 | Canon Elph Jr. APS Point and Shoot Camera
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
Jan 06, 2009 | Olympus Camedia C-725 Digital Camera
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Trying to update the date and Time
Press menu, press right cursor until you see the toolbox icon and press again to display the setup menu. Press cursor down until setup2(icon toolbox2). Press right cursor, then press down till clock set, press right cursor, press cursor up OK, then press center button, there you can set the clock, you can select whatever date format you prefer. thanks
Sep 13, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Sony Cyber-Shot DSC-P92 Digital Camera Logo
88 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
