Question about SanDisk Sansa e100 MP3 Player
MP3 Player is not turn on at all
I have bought sansa e140 one week back,It was working well for 4 days with out any problem. Suddenly it is not working for past two days.Not even turning on! System also not detecting this when i plug in!!!
  • musiqlova Nov 03, 2007
    i have a sansa e130 and have had it less than a year. the battery died and when i replaced it the mp3 player does not work and when the usb cable is plugged into the computer and the mp3 player it is not getting any power. i dont know if i downloaded a corrupted file. is there a manual reset that can be done?
SOURCE: my computer does not detect my mp3 player sansa 4.0 gb
how do you change it to MSC
Posted on Mar 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa clip mp3 player driver 2GB
The drivers and all software is available from Sandisk's website.
Posted on Jan 01, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Posted on Feb 28, 2009
  • 12 Answers
SOURCE: sansa e250...computer will not detect
If you are using a USB connector [that connects extra ports to your computer] it sometimes doesnt work... so if possible hook the USB sansa cable to the main ports in the back of the server. It might also work to hook it in, and then go to 'My Computer' and see if it shows up there. Good Luck =]
Posted on Jun 10, 2009
rockitman187
  • 2559 Answers
SOURCE: My PC (windows XP) doesn't detect Sansa e250 MP3 player
Turn the player off before you plug it in and if it doesn't find it then turn it on while plug in.
Posted on Jul 30, 2009
SD card suddenly says write protected; wasn't before - how do I fix?
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
Jun 18, 2010 | SanDisk Sansa e140 MP3 Player
How to add memory to sansa e140
try updating the firmware may be that should help
Jan 24, 2009 | SanDisk Sansa e140 MP3 Player
Hey can you tell me how to fi this problem my san disk e140 is telling me not enough memory cnnect to the pc delete 4m of songs for sansa system.i have tried everything it told me and it still do not work...
to solve the problem do the following things:
- download the firmware (http://www.sandisk.com/Retail/Default.aspx?CatID=1295)
- run firmware - SW
- FirmwareDownloader shows "Detecting"
- put oft the battery of the e140
- hold down the Power Button
- Connect the e140 to the PC
- FirmwareDownloader shows "Recovery mode ready"
- press start-Button
--> e140 works
Sep 28, 2008 | SanDisk Sansa e140 MP3 Player
Sansa e140 error
There is a Problem with the flash memory on the Mp3 player I would request u too replace it
Aug 03, 2008 | SanDisk Sansa e140 MP3 Player
E140 stopped working
I think u can call this customer service ph# 800-426-6027 to get assistance on service
Apr 04, 2008 | SanDisk Sansa e140 MP3 Player
My mp3 freezes up..can anyone help??
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
Not detecting sansae140
Pls call the customer service Ph# 800-426-6027 they will help u out with it
May 30, 2007 | SanDisk Sansa e140 MP3 Player
Changing batteries
Hello, I've actually had the same problem with mine. What happens with mine is the spring becomes loose or bent and needs to be (gently) pried back into it's original position. Hope this is of some help, Jenna
Jan 15, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa e100 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
