My Toshiba Laptop wassuddenly hanged and beepm sound was coming so i shut down the computer. When again i restarted it shwon me an error
  • santoshns Dec 08, 2008
    Operating sysgtem not found
  • Rob Duron
    Rob Duron May 11, 2010
    What was the error?
    Novelist:
    Champion:
  • 233 Answers
Your hard drive may have died. Try to boot from the Windows CD and maybe install to an external HDD.
Posted on Dec 26, 2008
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Laptop is run and start but no display
Monitor Toggle
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
How to go back to factory settings
All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
-Shut the computer down completely
-hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
-when the computer starts beeping release the 0 key
-when the prompt comes up choose YES to continue with system recovery
-Select recover of factory default software and click NEXT
-Click Next again to start recovery
Hope this helps!
Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
AppHang81 Error-help!
what version of windows are you using? state the version and servicepack. in the intrim, start your computer in safe mode and run some programs. shut down the computer and restart in normal mode.
Jan 02, 2010 | Compaq Presario CQ60-220US PC Laptop
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Toshiba Satellite L35 Windows XP won't boot up
well you might have to redo your hard drive sounds like some files in the operating system are corrupt go to your nerest computer place ask for addapter to connect your laptop hard drive to your pc then try to scan hard drive pull pics out then format harddrive
Oct 30, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
