Question about Cingular Wireless 8125 Smartphone
8125 CHARGER PORT BROKEN
CAN IT BE REPAIRED
  • RJKMed Dec 08, 2008
    my Charge port on my 8125 broke. Can anyone help?
Go on to ebay and type in 8125 port and you can see they sell new ports easy fix.hope that helps.
Posted on Dec 29, 2008
Will not recharge battery
It could be the charger or a broken port. Did you test the charger on another device? If the charger works use a tooth pick or similar object to test the port. If it wobbles around you will need to get it professionaly repaired or try your luck re-soldering the port yourself
Mar 06, 2015 | Tablets & eReaders
WHAT is one to do if the charger port is broken and WHAT is the port next to the charger port is that another type of charger port?
First of all, the port next to the charging port is a mini HDMI port for connecting your Kindle to a TV. As far as your broken charging port, you can either send it out for repair or repair it yours self. Check out this link to youtube for repairing the port. https://www.youtube.com/watch?v=ZWFMCIdZx2w You can find a replacement port at an electronics store like Radio Shack.
Jul 09, 2014 | Amazon Kindle Fire HD
Drivere sk-8125 pentru windows 7
If it's doing nothing then you have a bad USB port (move it to another USB port) or the USB keyboard is disabled in CMOS (usually hit F2 or Delete button during start up to get to). If the keyboard is working but isn't working correctly, there is something wrong with the keyboard. You probably just need a new keyboard.
Jan 30, 2011 | Dell SK-8125 Keyboard
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
1. get it repaired, under warranty if possible
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Charger on phone is loose
you need to solder it back into place ot instal a new one if yours is damaged. Please contact me if you are interested to send it in for this repair. cellularcpr@aol
Apr 26, 2009 | Cingular Wireless 8125 Smartphone
Will not power up on AC or usb adapter
If you have an extra charger for the phone remove the end take the exposed copper wires hold them to the positive and negative post's on the battery for about 3 minutes and then plug into the normal charger.
I know this works I did it to my phone last night.
Jan 07, 2009 | Cingular Wireless 8125 Smartphone
My phone wont turn on.
If the charging light comes on with the charger plugged in you probably have a broken power button. if the charging light does not come on while plugged in, your charging port most likely is damaged. take it to your local cell phone technician. if you havent any nearby you can contact www.fixphonenow.com ,they should be able to repair it.
t
Nov 16, 2008 | Cingular Wireless 8125 Smartphone
Htc 8125
there will be some problem in the charger or in the charging port of your cell ..
just have a check with the charger first with another mobile if needed replace it ..
if you still persist the same problem then there may be some problem in the charging port of your cell ..
the charging port may be is in loose contact ie it might not be touching the motherboard of your cell correctly just have a check by opening the cell if you are good at opening if needed replace the charging port ...
rate my solution
Sep 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
T-mobile mda usb port broken
try other USB ports on your comptuer and try it on another computer before trying to open it up
Nov 13, 2007 | T-Mobile MDA
Cingular Wireless 8125 Smartphone Logo
69 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
fordexpert
Erik Walters
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
