Question about HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7500 - printer installation ok, fax installation ok, but scanner driver does not work
  • Knight48 Dec 09, 2008
    1. I tried all of your ideas, and nothing worked. Scanner still fails to install, HP won't discuss it, and the sad part is they knew about this and released it anyway.
    2. Still Hangs at 96%, but will complete the install if you wait about an hour, but the scanner will not function.
    3. Fax never does install, so I run it manually.
    Frankley it is a piece of junk!
  • VballPLAR Jan 02, 2009
    I have the same problem. I have uninstalled and reinstalled the drivers per HP's help desk; didn't work. Even went in per HP's direction and manually removed everything and it still didn't work. I can scan from the MS scanner wizard, but that is it.
Mine was working with an XP machine. I have yet to get my scanner to work with the 64bit Win7 machine I'm currently using. I've tried reinstalling several times. Mine is a network installation. and at this point the scanner won't work with the Win 7 machine or my brother's XP machine..
Prints fine though.
Posted on Nov 09, 2012
Had a similar problem " with my L7590 allin one unit, "scanner did not function" from the Solution center. If your unit is plugged into a surge protector, unplug the unit from the surge protector and plug directly into the wall power socket. It solved my problem. Can you believe this.The explanation is that the printer goes into sleep mode it reduces the amount of power needed for its uses and the internal surge protector of the unit notes this; however, when you "wake the printer up" the difference in power usage between the two levels may be considered by the surge protector as a power surge and limit or halt the increase, disabling certain functions. George
Posted on Apr 15, 2009
    Guru:
  • 731 Answers
This must be scanner driver not communicating with the hardware.Try the following steps and i'm sure it will work.
1.Click start - >run then type "twain_32" click OK.
2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
3.Click start - >run then type "services.msc" click OK.
4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%"(without quotes) click OK. A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
6.Disconnect the Printer USB cable, Insert the
installation disk of your printer.If Installation wizard
pops up, click on cancel/exit.
7.open My Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_4". Double click on that file.
8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
9.After that, restart the PC and Insert the Disk and
install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
Please let me know, once you have done this
Thanks
Rizwan
rizwan84tx@gmail.com
Posted on Dec 08, 2008
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
I have officejet pro L7500, and i cant send a fax
put two pauses after the phone number then the extension
Jul 04, 2009 | Office Equipment & Supplies
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Jun 10, 2009 | HP Office Equipment & Supplies
Software Installation Problem
I understand your concern that you are unable to remove previous HP drivers installed on your computer. To resolve this download the HP software removal utility and run the utility.
Click here to download HP software removal utility.
NOTE: Select your OS and select HP software utility At bottom and click on download only. After dowloading run the utility for four times to remove the HP printer software completely from your computer.
After running the utility four times restart the computer and check whether HP Imaging folder is completely deleted or not which as located in C:/progra files/HP Imaging folder. If the folder is not there then the software is removed completely from your computer and continue to download the Full Feature software from the same link and install it.
Now try to scan from HP solution center. This should resolve the issue.
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Want to set Draft as Default Print Setting
Under Printers and Faxes in Control Panel (Classic View) right click on the printer and select properties then under Printing Preferences set Draft and click OK - this will now be the default setting.
Dec 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
My HP Officejet 4355 All-in-one is not compatible with Vista
you need to go on to the hp website and see if they have vista drivers for that printer
Nov 11, 2008 | HP Officejet 4355 All-In-One InkJet...
Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Aug 12, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Installin hp 9130 all in one without install cd
Contact hp & order a CD
If the download was not working this would be fastest & easiest solution.
What is your operating system?
Dec 06, 2007 | HP Officejet 9110 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
3,200 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
