Question about Whirlpool Duet GHW9150P Front Load Washer
GETTING A 'F-' CODE WITH NO NUMBERS ON MY DUET SPORT????
IT WILL START THE WASH CYCLE,DOOR LOCKS,ADDS WATER,AND WASHES FOR ABOUT 10 MIN. THEN IT STOPS ALL TOGETHER AND BLINKS F- . IF I PUSH THE PAUSE BUTTON IT WILL DRAIN AND THEN SHUT OFF.I NOTICE THAT WHEN IT HAPPENS THE WASH AND SPIN LIGHTS ARE ON AT THE SAME TIME. ITS SAD HOW A COMPANY CAN SELL US ABSOLUTE JUNK AND DO NOTHING ABOUT IT...NEVER AGAIN WHIRLPOOL...
  • Ron Coons
    Ron Coons May 11, 2010
    the code that its FAulty on is actually the number that blinks after the "F" dissapears,would need to know that to diag any furhter
I had this same problem pull the bottom panel off. There will be a white plastic filter turn the knob it screws off, pull out the filter . Cleaning the filter should fix this problem it did for me.
Posted on Dec 08, 2008
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
I have a duet sport WFW8300SW02 which I am having
Here is the code meaning
F26 is for door lock - do you hear the door lock one time or with click sound repeatedly.
F20 no water entering - do you check water coming into washer
F21 long drain-do you take a look of pump filter
Another possibility is the pressure switch was bad.
Hope you can figure out the issue.
Oct 19, 2013 | Whirlpool duet Washing Machines
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
