Question about Nikon D200 Digital Camera with 18-200mm Lens
NikonD200 I have just purchased a Nikon D200 and my images appera muddy or yellow tinged not only on my viewing screen but also on my computer. I have customised my settings mostly using normal can you suggest what i should try.i am using a nikon SB800 flash unit & WB is set on flash
    Novelist:
  • 107 Answers
The symptom you describe sounds like an incorrect white-balance setting when you take the images. Digital cameras are sensitive to the quality of lighting seen when your taking pictures. First thing to try is to manually select a white balance setting and try the photos again. Try google or your manual to find instructions on how to do that. The camera can auto-adjust to some lighting situations, but fails to properly compensate in other situations resulting in the muddy or yellowed images you have seen. There is a product called "expodisc" that corrects for this white balance problem as well. Look it up. David Millier Advance Camera Repair
Posted on Feb 24, 2007
Any grid in nikon D200?
To turn on the Grid Display in the view finder...
Press Menu button, then go into the Custom Setting Menu (looks like a pencil). Select "Shooting/Display", then select "Grid Display", select "On" then "OK".
Happy shooting!
Sep 26, 2009 | Nikon D200 Body Only Digital Camera
Nikon D200 images not sharp
Your camera settings may be off. The D200 is very flexible when it comes to personalizing your settings, but they can be hard to navigate.
Try resetting using the built in reset feature. This will not affect your personal settings but may clear any unwanted changes. To do this, find the "QUAL and +/- " buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks then the camera is reset.
This resets things like resolution, White balance and ISO settings.
Next, try setting your metering matrix to the middle position. Not the top and certainly not the bottom postion. This switch is located on the right side of the view finder.
If your lens has a "M/A - M", use the M/A setting.
There are three settings for focus. C, S, and M, located on the front of the camera next to the lens. Set your camera focus to "S". This will set it up for still subjects and prevent the sensors from tracking things that move. Also set on the AF area mode switch on the back of the D200.
Try these settings. If your images are still out of focus, you may have other issues that may require servicing by an authorized Nikon facility.
Apr 13, 2009 | Nikon D200 Digital Camera
Lcd preview blank d200
you cannot "Preview" shots on the LCD screen with the D200. There is no Live View function. Newer models such as D300 and D90 offers such a feature.
Nov 10, 2008 | Nikon D200 Digital Camera with 18-200mm...
Dust inside my d200
The view finder and focusing screen are separate from the CCD sensor. The mirror reflects the image to the view finder until you take a picture. Then the mirror goes up, the shutter opens to expose the CCD to capture the image.
If you have a lot of dust, you should look into a cleaning kit, or have it professionally cleaned. This will show up on your images as white and/or black specks.
Jun 29, 2008 | Nikon D200 Body Only Digital Camera
Unwanted flash fire in nikonD200
Hi, I had the same sort of problem. It started with erratic small flashes but then evolved to the SB-800 not regonizing the D200 at all. The result of this is that I only get TTL and not TTL+BL+FP functionallity.
To solve this I cleaned the hotshoe on the D200 with all purpose cleaner for electical appliances (CRC 5-56). This gave minor improvment. Then I adjusted the spings to the left and right on the hotshoe on the D200 to press harder against the flash's connection (which I suppose is the grounding). Now everything works again.
Best regards,
Marcus
Jun 21, 2008 | Nikon D200 Body Only Digital Camera
Problem with importing images to laptop(macbook) from nikond200 trough data cable
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
Apr 12, 2008 | Nikon D200 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D200 Digital Camera with 18-200mm Lens Logo
136 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
