Hello Bubba hi is it possible to scanfrom richo aficio 1085 to the pc
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does this copier have an ethernet connection connected to it?
    Problem Solver:
  • 7 Answers
Yes it have Fiery EB 105e
Posted on Dec 12, 2008
How to fix sc990 on richo 1085 copier
Have you done the PM? If not perform PM.
Feb 20, 2015 | Ricoh Aficio 1085 Laser Printer
How do I put a new supply of staples into Richo Aficio 1060
Please refer to your manual on how to install your new power supply. To ensure that your device will not damage or destroyed.
thanks
Jul 31, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
While I am running richo aficio 1085 Pcl, It stops and show the code sc550. I try to switch the machine turn on and turn off alot of time but the result is the same, How can I do to remove this problem?
Oil Supply/Cleaning Web End. Change this and
Press the following keys in sequence.
Total Clear key 1 0 7 and clear stop for more of 3 second to enter to service program mode, eter to 1902 - 1... and change the value to 0%.
shut down the machine and turn on.
Jun 30, 2009 | Ricoh Aficio 1085 Laser Printer
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
May 27, 2009 | Ricoh Aficio 1085 Laser Printer
Use as a scanner .... How to ?
you must first connect scanner interface drive board
Jan 22, 2009 | Ricoh Aficio 1085 Laser Printer
Hiricho aficio 1085
you need to activate scan to folder feature, under system properties
Dec 08, 2008 | Office Equipment & Supplies
Hello Bubba how can i found cable for aficio 1085 to pc
Make sure your copier has a parallel port attached to it.  Then you simply need a parallel cable to connect it to your computer.  Some computers may not have a parallel port on them.
Oct 08, 2008 | Office Equipment & Supplies
Hello Bubbab
http://www.timatech.com/products.php?pd_pn=PAN064-CP
Sep 17, 2008 | Office Equipment & Supplies
Hello MR dricha
If the developer has been changed.  You need to go into service mode to calibrate it before you print.  If you don't run the program and you make copies, copy quality will change and you may have to replace the developer again.
Once it is replaced go into service mode and issue the service code to calibrate the developer.
If you haven't replaced the developer yet, you should.
Sep 12, 2008 | Office Equipment & Supplies
66 people viewed this question
jasbo
jasbo
