Hiricho aficio 1085
how can i scan to the pc from richo aficio 1085
  • ma7moud fayed Dec 10, 2008
    how this activate doing
  • 446 Answers
You need to activate scan to folder feature, under system properties
Posted on Dec 10, 2008
  • ariel santos
    ariel santos Dec 11, 2008
    scan to folder feuture is the way to save your doc scan from your printer directly to your specified folder in your pc, thats what you need to do and activate
How to fix sc990 on richo 1085 copier
Have you done the PM? If not perform PM.
Feb 20, 2015 | Ricoh Aficio 1085 Laser Printer
Richo Aficio g7500 printer error 950. Replaced new ink woill not recognize the new full cartridge???
HI there try this.
1. try to reset the printer & clean the printer head by some alcohol and the see what happend. If not solve then follow the step 2.
2. Uninstall the printer driver and restart the PC . Now again install the printer driver and try. I hope this time your problem will solve.
Thanks. Let me know the result.
Nov 28, 2010 | Ricoh Aficio G7500 Printer
While I am running richo aficio 1085 Pcl, It stops and show the code sc550. I try to switch the machine turn on and turn off alot of time but the result is the same, How can I do to remove this problem?
Oil Supply/Cleaning Web End. Change this and
Press the following keys in sequence.
Total Clear key 1 0 7 and clear stop for more of 3 second to enter to service program mode, eter to 1902 - 1... and change the value to 0%.
shut down the machine and turn on.
Jun 30, 2009 | Ricoh Aficio 1085 Laser Printer
I want download the engine firmware ricoh aficio 850 1085 105e
When I can download the firmware cicu / bcu 8.1 by ricoh aficio 1085?
Mar 27, 2009 | Ricoh Aficio 450 Copier
RICHO 2015
Make sure there are no firewalls turned on your computer. All firewalls should be controlled on a router.
Are you using the web interface from the copier to download them?
Mar 09, 2009 | Ricoh Aficio 2015 Copier
Use as a scanner .... How to ?
you must first connect scanner interface drive board
Jan 22, 2009 | Ricoh Aficio 1085 Laser Printer
Hello Bubba
yes it have Fiery EB 105e
Dec 08, 2008 | Office Equipment & Supplies
Hello Bubbab
Sep 17, 2008 | Office Equipment & Supplies
Hello MR dricha
If the developer has been changed.  You need to go into service mode to calibrate it before you print.  If you don't run the program and you make copies, copy quality will change and you may have to replace the developer again.
Once it is replaced go into service mode and issue the service code to calibrate the developer.
If you haven't replaced the developer yet, you should.
Sep 12, 2008 | Office Equipment & Supplies
Ricoh Aficio 1085 Paper Tray 1 Jamming
you can change the tray setting in user mode to tray 2 and same time do not fill the tray one. same apply on print job from a computer, select tray two as default with print driver.
Jan 07, 2008 | Ricoh Aficio 1085 Laser Printer
