Question about KitchenAid KAWS850L Top Load Washer
We have a kitchenaid model kaws850gq0 dont wash
This washer is not responding to fabric select it seem's to be stuck on delicat . the agitator seems to be spinning free while washig could it be be that the agitator drive is broken or sould i look for electrical troubles
    President:
  • KitchenAid Master
  • 2,651 Answers
Dont reeally undserstand question, you can freely turn the agitator freely, in both directions??? with no resistance??? if so you need to replsce the agitator dogs, part number 80040, probly under $20, to replace youll need to remove the agitator form the tub( 7/16 bolt under the fabric softener cup "pop" it off with the palm of your hand!
Posted on Dec 08, 2008
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
Hello, the agitator seems to work (and turn) well at the bottom but it seems stuck at the top (hardly turns. What can I do? Thanks, Isa
If it has a fabric softener dispenser in the top, it is most likely a waxy buildup from the lanolin in the softener. Disassemble and clean.
Sep 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The agitator in the machine stopped working. I can spin it freely by hand in either direction
Sounds Like the agitator dogs are worn or broken. they are easy to change
  1. Remove the Fabric Softener Dispenser (#1 on diagram)
  2. Remove the Agitator Bolt. (#2 on diagram)
  3. Replace the Agitator Repair Kit
There are 3 Lengths of agitator cams
If you go to http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503228&diagram_id=28254127#d28254127
And Click on #20 on the Agitator, basket and tub Diagram
You can see pictures of the 3 lengths of cams order the one that matches your washer
Jun 25, 2011 | KitchenAid KAWS700L Top Load Washer
2008 model number not found on selection list, model #nfw7200tw washer did not spin and drain out dirty water and complete rinse and spin dry cycle, tried to reset by manual instructions and it would...
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. If this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift it up hard... see the picture. Hope this helps...please post back for further assistance.
Daniel
Feb 05, 2011 | Amana Washing Machines
KitchenAid Stylemaster 622784 cleaning the fabric softener dispenser. I can't get the fabric softener apart to clean it. I don't have a manual. I bought it, used, with no manual. Suggestions?
Hi
Thanks for using FixYa. Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | KitchenAid KAWS850L Top Load Washer
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Need to remove Agitator
On a MAV6000, you should be able to pop off the fabric softner cap, remove the fabric softner cup underneath, and finally remove the bolt underneath to lift up the agitator. (rocking the cap back and forth is usually the best method)
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
107 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
