Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
For some reason my printer keeps saying paper jammed. I have done everything possible and there is no paper to clear. It is not even pulling the paper up to print on it. However, I cannot print anything because I cannot clear the Paper jammed problem. Can you please tell me what to do???
  • lenajoze Mar 22, 2009
    my printer is not pulling the paper through and makes a crackling noise everytimes I plug it back in. I am checked every little bit of the printer for paper pieces but my printer is clean. It started after one year (minimum use) to have problems with paper pulling. Now, it just stayes jammed and won't pull the paper at all. It gives me the error message that the paper is jammed. It's now only two years old. For the price I paid it is not worth getting it fixed, but I have three very expensive catrages which I can't bring back to the reseller. I would have to through not only $70 out but $140.
How i can i plug mymulti-function center mfc model mfc240c to my pc
Posted on Apr 24, 2009
  • roger1710 Apr 24, 2009
    hello how can i plug mymulti-function center mfc model mfc240c to my pc
  • ray crosby Dec 18, 2011
    I have a brothers MFC240C you can get the soft ware on line and all thats left is to plug the usb cord from the printer into a port on you'r pc and plug the ac cord into a wall receptacle;thats all I had to do
How to remove jammed paper from brother printer model mfc 845cw how
Open the Cover of the Printer and Remove the Cartridge from the Printer After you can remove the jammed paper from the printer.
Jun 28, 2014 | Brother Multi-Function Center MFC-240C...
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
My mfc 240c always shows paper jam, and nothing found
please printer in open the head couver and check the paper and other
small parts paper in printer and you carteriase out of printer and
check the paper and printer in back side in fixes paper to out and
clean the printer and close the couver is ok and apply the plug printer is on and aply print ok
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Error 30 after jammed paper on brother MFC-240c
Open the front and the rear panel and make sure there is no bit of paper jammed. Also make sure there is no dirt in the printer roller
Jul 03, 2009 | Brother Multi-Function Center MFC-240C...
Error 50 after jammed paper on brother MFC-240c
I had this too, I had to open the back of the machine, it is meant to open and pull out and clear the jam (pull out the crinkled paper) but everytime I tried to print again it kept saying that it still had the jam, I opened and closed it several times and it did not seem to register that I HAD CLEARED THE JAM, so what I did was unplug it from the wall and then plug it back in and then it was fine. I wonder if this is AN ACTUAL DEFECT with this machine, if ater a paper jam it cannot detect that it has been resolved without having to unplug it and plug it back in, HOPE THIS WORKS FOR YOU.
Feb 24, 2009 | Brother Multi-Function Center MFC-240C...
Mfc240 all in brother printer
i need the install utilities cd to program my mfc-240 machine
Sep 06, 2008 | Brother Multi-Function Center MFC-240C...
Brother mfc 240c
no. there is another alignment which can only be done by sevice personell. you have to take the machine to a service partner.
Apr 01, 2008 | Brother Multi-Function Center MFC-240C...
Printer unjammed still not working
check the very edges. thers some paper left.
Mar 17, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
471 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
